Offsets are no problem. Since you are only running a 9 in the front might i suggest running a 255/30? My 265's had a slight rub, but also the tire will look bulged in the front compared to the rear.
255/30 and 285/30 would be perfect for your setup.
Thanks for the advice, I was hung up on if I should run 255 or 265. I will try the 255 setup up front.
Thanks...always tommy...no adapter needed for tpms, but we couldn't get it to work with techstream... its sad that they don't have that option like for the IS F.
What is the offset of this set up? any rubbing issues?
20x9.5 +30 265/30
20x11+40 295/30
If your stock height no rubbing, If you have Swift springs, you need to replace the bolt holding the side skirt on the fender side to a bumper tab and your good
