Brake Rotors for F-Sport
Hello fellas/ladies,
I'm trying to purchase some front brake rotors+pads for my RC unfortunately i ordered one through amazon and it didnt fit.
I have a
2015 RC350 FSport RWD
if someone can point me to the right direction I would greatly appreciate it.
Thank You in Advance
I have a
Hey,
I recently changed my 2 front rotors as well - exact same model and year as yours.
I found that in terms of aftermarket parts, there doesn't seem to be a huge selection compared to other vehicles.
However, I believe Racing Brake does a pair of the front rotors.
A couple of the vendors on here might be able to help you out too, if you haven't given them a message.
I ended up just replacing mine with OEM ones though - more so due to the fact that it was just a bit difficult to get aftermarket ones where I'm located.
If it helps, the OEM part numbers are:
43512-30371 : Front Right
43516-30061 : Front Left
Not sure, but maybe you could use them as a reference to find other parts that fit.
In terms of brake pads, most companies should be able to help you out if you tell them your make and model and ask for a 4 piston variant. (If you have the stock callipers)
I used QFM HPX brake pads - but then again, it's an Australian company, so it might be easier if you sourced something local!
Apparently Endless do one too, if you're looking for something a bit sportier.
Hope this helped a tad.
is250smoke
06-03-16 08:36 AM
