RC200t downpipe
Old Jun 25, 2018 | 07:04 PM
tnilc's Avatar
tnilc
Originally Posted by Rob200t
Nah not yet, I’m also getting a tune pretty after and they said that even if I get a cel with the downpipe that the tune should take care of that
I need to find a tuner in my area to do that, I've been thinking a BMS Tune but that won't get rid of the CEL
Old Jun 25, 2018 | 07:08 PM
Rob200t's Avatar
Rob200t
man if you want you can pay for a obd2 scanner
Amazon Amazon
now what this will allow you to do is erase any check engine lights but I’m not use if your dealer checks it, it may or may not pop up again. So there is that option!
Old Jun 25, 2018 | 07:11 PM
tnilc's Avatar
tnilc
https://www.amazon.com/gp/aw/s/ref=i...2+code+scanner
I have one. PPE said if I'm throwing a p0420 code, I need to try the largest restrictor in the O2 adapter. Hopefully this works and my CEL goes away. I'm just waiting for the car to cool down.
Old Jun 25, 2018 | 07:13 PM
Rob200t's Avatar
Rob200t
What did they mean by “try the largest restrictor? Like pull that one out the way?
Old Jun 25, 2018 | 07:16 PM
tnilc's Avatar
tnilc
They sent me an o2 adapter that came with a spacer and different sized restrictors. I had the smallest in, installed by the shop and it threw a CEL. I contacted PPE and Figs, PPE said try without the restrictor but if it still has a CEL to check the code. If it was P0420 they said to run the largest restrictor. Figs off the bat said try running the largest one. I hope this works.
Old Jun 25, 2018 | 07:18 PM
Rob200t's Avatar
Rob200t
it didn’t come with the downpipe did it? They sent you that seperatly? And did you have to pay for the spacer or did they send that to you free of charge?
Old Jun 25, 2018 | 07:45 PM
tnilc's Avatar
tnilc
It did not come with the downpipe, I emailed Figs inquiring about it and they asked for a picture of what I sent. I forgot about since I ordered a 90 degree angled one on Amazon that another user recommended. I got a package in the mail from Figs with the O2 adapter afterwards. My shop said they couldn't install the 90 degree adapter since it hits the transmission, so they'd need to uninstall the downpipe to do it...but since I had the other adapter from Figs I went with that instead. Unfortunately I have to do trial and error to find what restrictor will work, instead of going back to the shop I just uninstalled the secondary O2 and adapter and have been testing different fittings.
I'm really hoping this latest trial works.
Old Jun 25, 2018 | 07:47 PM
Rob200t's Avatar
Rob200t
dang, is yours straight pipes or a high flow cat? Mines a cat so I’m not even sure ima throw a CEL, but I’ll find out soon enough
Old Jun 25, 2018 | 07:54 PM
tnilc's Avatar
tnilc
Decatted, if you have a cat you won't throw a CEL
Old Jun 25, 2018 | 07:56 PM
Rob200t's Avatar
Rob200t
dang so I was stressing for nothing cause I thought I wouldn’t but some people said (on YouTube) that youll probably throw one anyways. But have you felt the difference and in noise with the downpipe? Or not really?
Old Jun 25, 2018 | 09:37 PM
tnilc's Avatar
tnilc
Success, CEL gone.
Old Jul 3, 2018 | 01:18 AM
tnilc's Avatar
tnilc
Sadly my check engine light came back.
Old Jul 5, 2018 | 12:18 AM
Rob200t's Avatar
Rob200t
Shoot bro. I actually had to delay the installation of my DP cause my car has an exhaust leak so I’m getging it seen this Friday but it’s most likely just a loose bolt or gasket hopefully nothing to worry about. Then soon he that DP and a charge pipe in soon. Almost done performance wise with the vehicle and then get a dyno tune coming in, in about 2 months max
Old Jul 10, 2018 | 06:01 PM
Sheddy's Avatar
Sheddy
This is the spacer I have on my PPE decatted pipe. No CEL with stock tune as well.
Old Jul 10, 2018 | 08:23 PM
tnilc's Avatar
tnilc
New O2 adapter in, wish me luck. 75 miles so far so good.
