My Atomic Silver with wheels and a drop
I love the lowered look and am seriously contemplating lowering my RC AWD with these springs. Having never had suspension work done on anything close to this expensive a car I am looking for some advice as to who you have do this work. I live in Denver and can't seem to find anyone via the Internet that has any experience lowering a Lexus. Obviously I know that cannot be true in such a sizeable metro area, but I feel like maybe I'm searching the wrong terms. I know y'all don't live in Denver but any advice you veteran suspension folks can share would be much appreciated!
This is the sort of project that most reputable performance shops should be able to handle for you. The job isn't complicated, just time consuming. They'll pull the wheels and then the factory struts, compress the factory springs, then replace the springs on the struts with the Tanabe springs (removing a coil if you want it a little lower) then reassemble that corner of the suspension in reverse order of disassembly. I believe the rear has separate springs and shocks, but most of the steps would be similar. You should search for an automotive performance shop to find a suitable mechanic for this job. It will take them around 4 hours to do all four corners.
Gents - I started out to use the Tanabe NF springs for the GS ... the back fits the F model no problem (although only lowers about .25 inches) ... the front springs, do not fit (on the F) ... the spring perch is different from the non-F models. Diameter of perch is smaller than the bottom diameter of coil so it will not seat at all.
My project is a work in progress using coil overs but I am still currently running stock dampeners in the rear. This weekend I will finish and have adjustable dampeners in the rear and THEN I will do the alignment. I was waiting to finish this weekend and then I can share my results with everyone... right now because I have aftermarkets (adjustable) struts in the front and stock in the rear, its difficult to comment on ride quality but so far everything has worked out great. I was able to dial the ride height exactly where I wanted and the ride quality even in it's current state is more than acceptable.
So yes, while I am lowered, I do not know officially if there are going to be major alignment concerns, that why I was curious if the OP had any input there. I'm optimistic as it doesn't look like the camber really changed drastically. I just noticed that there was also no factory adjustment for it. I'm sure the bushings from another model will likely work if needed.
