Help with uploading Sig
Old Oct 4, 2002 | 07:05 PM
GLGTOY's Avatar
GLGTOY
Unhappy Help with uploading Sig
I have managed to put some kind of Sig. together for now. But I have not been successful in loading it up. I followed instructions as per a previous thread but I still am not getting anywhere.
I was able to load the Sig into the lexus gallery. Then I took the URL and pasted it on the appropriate box in user cp. It looks like this.
[img]https://www.clublexus.com/photo1/showphoto.php?photo=7145
[/img]
What am I missing.
Old Oct 4, 2002 | 08:38 PM
LS400's Avatar
LS400
Club Lexus Editor
Default Re: Help with uploading Sig
[img]http//clublexus.com/photo1/showphoto.php?photo=7145[/img]
What am I missing.
You forgot the ": after the "http" part.
It should be http:
Hope that helps.
Old Oct 4, 2002 | 08:53 PM
GLGTOY's Avatar
GLGTOY
Thanks LS400. I put in the : but now I get a box with and X in the middle. I guess I am making progress.
Thanks for you help
Old Oct 4, 2002 | 09:30 PM
Daddy-O's Avatar
Daddy-O
GLGTOY,
This is the type of code to insert in your signature:
{IMG}https://www.clublexus.com/photo/data...9lexus_sig.gif{/IMG}
Just replace these {}, with these []
Please note, however:
Max Sig Image Dimensions: 450 pixels wide X 100 pixels tall
Max File Size: 50K
Max Text: 8 Lines, including blanks
Images and text may be combined in your signature.
Max File Size: 50K- The graphic you've chosen is currently 99K.
Too large for CL. The graphic must be reduced. Thanks
Old Oct 5, 2002 | 10:03 AM
GLGTOY's Avatar
GLGTOY
Unhappy
Daddy-O. I changed the size of the file. It is now under 50K. Thank You. I did not know.
I already have these [] in the line. I tried putting these {} in but still no result.
My current line looks like this:
[img]http//clublexus.com/photo1/showphoto.php?photo=7151[/img]
I left the : on purpose so you can see the line.
Old Oct 5, 2002 | 02:22 PM
Daddy-O's Avatar
Daddy-O
GLG,
When using an IMG tag, there must be an image reference to within the tag.
Right click in the image in your gallery:
https://www.clublexus.com/photo1/sho...php?photo=7151
and choose Properties. You will see an Address (URL) for this image.
This is that code (path) that must be placed between the Bracketed IMG tags in your signature.
Old Oct 5, 2002 | 02:45 PM
GLGTOY's Avatar
GLGTOY
Thumbs up
Yes.....
That was it. I was using the wrong URL.
Thanks for all your help Daddy-O
mp311mp
Site Suggestions & Problems
Oct 28, 2003 09:42 PM
lexusnexus
May 6, 2003 03:11 PM
