Check engine p2757 and c1201
Old Dec 7, 2021 | 01:11 AM
AnaJanak's Avatar
AnaJanak
Default Check engine p2757 and c1201
Hello, I have Lexus IS 250 from 2006 year with automatic transmission and I have codes P2757 and C1201. I changed the solenoid, oil and filter for the transmission.
Are these codes connected with the ecm and tcm, should I buy knew computer or the problem is with something else?
Old Apr 28, 2022 | 09:13 AM
Jrg213's Avatar
Jrg213
Did the solenoid change make the p2757 code stop? I have the same codes show up periodically and I'm thinking about changing the solenoid out. Thanks
Old Jul 17, 2022 | 10:46 AM
MrHarris's Avatar
MrHarris
any updates?
Old Nov 18, 2025 | 09:50 PM
lexusareawsome's Avatar
lexusareawsome
1st Gear
Do you guys have any updates on this issue? I changed the solenoid on mine but the codes are still popping up, do you guys know how to fix this issue?
moekazem
RX - 1st Gen (1999-2003)
36
Jun 3, 2025 08:15 PM
bloodyKnuc
Maintenance
Jul 3, 2021 10:15 AM
axis77
Sep 13, 2019 06:54 PM
parnassus
Oct 7, 2018 06:46 PM
cdvmagic
Maintenance
Dec 16, 2006 03:25 PM
