Wiring fuel pump for key on operation.
Old Mar 4, 2021 | 05:27 AM
TrueGS300's Avatar
TrueGS300
Nice, I need to retest mine, but do you mind taking pics of exactly how you ran the wires? Maybe I can see if I did something wrong.
Old Mar 4, 2021 | 03:55 PM
KyleH's Avatar
KyleH
Sure - Used this as my guide - check out the installation instructions: http://www.radiumauto.com/DIY-Fuel-P...-Kit-P368.aspx
There are 4 wires from the relay.
1) + from battery
2) Trigger for relay; tapped into stock fuel pump wire (activated with key "on")
3) + to Fuel pump - soldered the (3) to a stock pigtail lead
4) Ground to chassis ground - at seat-back anchor bolt
You may have wondered how I was getting alternator-level reading with my volt meter while holding the power plug in my hand - how was the engine running? Well, I essentially have a redundant solution as far as pump power goes. I retained my stock harness and plug because I didn't want to hack it up. I also bought an extra pigtail off an IS300 salvaged car that I wired to my upgraded fuel pump wiring. I then simply depinned the fuel sensor / level wires from the stock plug and pinned them into my "new" plug. This results in me having a fully pinned plug for my heavy gauge wire lead. But in the event I have a problem with my solution and blow a fuse, etc., I retain the original plug and power (albeit without the fuel level wires connected) to limp home. So to get that picture, I was driving the pump with the stock wiring & plug, and metering the power coming from the battery & relay via the upgraded wiring to the "new" plug.
Crude wiring diagram
Grey is upgraded plug / wiring pigtail. White is the stock plug / wiring retaining only the stock + and - fuel pump wires.
Overview with grounding location in lower right corner
4 relay wires - red = +, black = -, blue = trigger
Wiring overview
UTsleeper
21
Jun 3, 2024 06:12 PM
jdbayer
RX - 1st Gen (1999-2003)
Jan 21, 2020 08:35 PM
Hayk
28
Sep 17, 2012 10:20 AM
MIGS
Dec 18, 2010 07:07 PM
esvan
Apr 16, 2010 07:42 PM
