03 is300 Clutch issues
Old Jan 4, 2020 | 04:50 PM
LeonXll's Avatar
LeonXll
Default 03 is300 Clutch issues
So I have a 5 speed 03 IS300 and I can drive it normally but when I start to dog it my rpms shoot up and I have to let go of the accelerator for it to catch again. So I just replaced my slave cylinder Bc my clutch pedal felt like it would lose pressure. Since then it still feels like it’s slipping but it’s not as bad after replacing the slave cylinder. Probably gonna swap out the clutch master cylinder next but any opinions would help out.
Old Jan 4, 2020 | 04:52 PM
Nad1370's Avatar
Nad1370
sounds like your clutch is worn out and is slipping under high load.
Old Jan 4, 2020 | 05:15 PM
Moisture's Avatar
Moisture
No kidding................
Old Jan 4, 2020 | 07:33 PM
Margate330's Avatar
Margate330
... but when I start to dog it my rpms shoot up and I have to let go of the accelerator for it to catch again.
I agree with others you clutch is toast I'm sorry man.
Old Jan 6, 2020 | 12:26 PM
bmwteaser's Avatar
bmwteaser
replace it with a turbo Supra/SC300 clutch and flywheel
Old Jan 22, 2020 | 07:34 AM
daddystop's Avatar
daddystop
Yeah the hydraulics will do nothing to fix your worn out and slipping clutch. The only thing that holds this torque is the pressure plate, the flywheel, and the friction material on the clutch disk.... all of which the hydraulics of the clutch system have nothing to do with.
You're going to have to replace your clutch.
Max88
Aug 31, 2017 06:58 AM
pandaboyx
IS - 1st Gen (2001-2005)
Mar 16, 2014 02:11 AM
omarmest
Nov 30, 2013 06:36 AM
tokyojack
Performance
Mar 31, 2011 10:09 PM
13s_is300
Jun 24, 2010 04:05 PM
