Tires: Uneven Wear
Old May 13, 2019 | 09:47 AM
vacmorales's Avatar
vacmorales
Default Tires: Uneven Wear
Have other had Issues with tire wear? My front tires seem to be giving out too soon. Most my wear has been on the inside/outside. Inside significantly worst.
Old May 13, 2019 | 09:55 AM
Flash5's Avatar
Flash5
There are 100 threads on this issue. Search it in the upper right search bar. Best fix is stiffer LCA bushings.
Old May 13, 2019 | 03:30 PM
vacmorales's Avatar
vacmorales
Thanks for that. I haven't however found anything for this issue on rear tires? have you or anyone seen it before? I had similiar toe wear on back tire.
Old May 14, 2019 | 01:34 AM
Flash5's Avatar
Flash5
For rears you need SPC rear camber arms. I have those installed as well because my rear camber was at about -2.2 and I got it dialed in to -1.5 with the camber arms.
Old May 27, 2019 | 11:00 PM
TonyN's Avatar
TonyN
I went with spc rear camber arms, -.10 camber and .015 toe
RVCAis250
Feb 15, 2013 08:45 PM
uncandid
Jul 3, 2012 03:16 PM
Fuzzie
Suspension and Brakes
Mar 24, 2011 05:56 PM
blklexo818
50
Oct 22, 2008 02:54 PM
Jasoneo5
Wheels, Tires & Brakes Forum
Nov 16, 2005 09:19 AM
