Limited clutch options for '08 IS250?
Old Jun 16, 2022 | 09:39 AM
  #31
Coopsis250's Avatar
Coopsis250
8th Gear
Originally Posted by Ultra4
The SL25A, ACT disc and LUK pressure plate are working well behind the 3GR-FSE. A bit grabbier than I want, but that's the price of my laziness for not deleting the delay valve yet.
Edit: just saw the parts you hid in the title. The disc you mention is unsprung, which is generally regarded as a bad idea with the single-mass setup. 1.125", 21 spline, max OD just about 10"...I'm not sure if a 10" disc would work or not. Lots of options to choose from, from basic organic to ceramic/kevlar multidisc hybrid.
Edit2: Aisin CKT-022 appears to be sprung, organic, and relatively affordable
Edit3 since you complain of it being underpowered, I suggest a Y38 or Y58 differential swap, so you're actually applying power to both rear wheels, instead of skateboarding off all the rubber they put in the suspension. That iconic IS250 6MT "na-na-na-na-naaaaaa" start goes away with the new diff.
thank you ultra I got that aisin clutch with the car when I bought it so I’m more looking for a flywheel to match, I haven’t even thought about changing the dif, thank you for the great idea!!
Old Jun 16, 2022 | 11:19 AM
  #32
Ultra4's Avatar
Ultra4
Well, in regard to the fly, the single masses should all be roughly identical in dimensions and performance. Unless there's a steel one I haven't seen yet, then that'll be a little more massive and friendlier to the factory diff gearing. If you don't use a sprung disc with a SMF, the trans and diff with take turns wiggling around until something in the trans lets go.
If you already have the DT156 and insist on using it, then I'd say stick with the dual mass flywheel. Nobody I'm aware of here has had a good time with a single mass fly and an unsprung disc. You need like a 5.32:1 diff and dummy thicc tires to make that make sense. Pretty sure at least one 6MT from here got wholesaled off because of that.
Edit: and never machine a DMF. If you find someone willing to machine a DMF, don't let them touch your stuff, and certainly don't pay them to do it.
Old Dec 13, 2023 | 01:42 PM
  #33
lexkid23's Avatar
lexkid23
1st Gear
Originally Posted by Jeff Lange
Toyota sizes their clutches and pressure plates to match the application, either by diameter differences and/or spring strength, similar to most other manufacturers. For cars, most of their clutches are typically one of the following sizes: 180, 190, 200, 212, 224, 230, 236, 240, or 250 mm, usually with a 19- or 21-spline shaft but there are others. For trucks, sizes are usually one of the following: 212, 224, 236, 250, 255, 260, 270, 275, or 300 mm, usually with a 14- or 21-spline shaft but there are others. Vans and other utility vehicles are usually mixed somewhere between them.
The clutch on the RA62 is somewhat unique, but also somewhat common to other Toyota setups. It is a pull-type clutch which is similar to the R154 and V160/161, in fact the release bearing is the same as the V16x and the pressure plate is the almost the same design as the 2JZ-GE V161 (like the GTE's pressure plate, but without the cooling fins and with a lighter clamping force). The flywheel is unfortunately quite unique in the IS250, even though other vehicles also use the AY6 and Toyota has used dual mass flywheels in several applications. Even between the IS200d/IS220d and the IS250 which all use the AY6, the flywheel is noticeably different for the IS250. The two biggest things that are unique compared to other Toyotas is the large step between the pressure plate mounting surface and the friction surface (approximately -8 mm from memory), and the actual overall thickness of the flywheel. The only other Toyota off the top of my head that used a similar step was the 4A-GZE and its 224/230 mm flywheel, though I suspect there may be another couple out there.
Other GR/AY6 setups use a push-type clutch with a larger 275 mm disc. The crankshaft bolt pattern is different between the 1GR and 2/3/4GR. The bellhousing on the RA60/61 is also larger to accommodate the larger diameter (but much thinner) flywheel.
This is one spot where the GM 3.6L setup is somewhat similar to the Toyota setup, the GM flywheel has a similar step, but is much thinner overall.
While the size and material of the original disc is nothing special, the factory disc is unsprung (as the flywheel dampens vibrations) and not used in any other application. If you go to a dealership, they will sell you a 31250-53050, which looks like this:
Attachment 489176
The 31250-33032 is only used if they are performing TSIB L-SB-0059-11 (USA) or TSB L-TCI-2960 (Canada), which also includes replacing the transmission with updated part 33030-53370 to get rid of the abnormal noise on some vehicles when releasing the clutch. Otherwise they will just be putting the original unsprung 31250-53050 back in there. Either way, the goal was to get rid of the abnormal noise, not affect the way the car drives, hence the car will drive about the same (I've had both the original transmission with the unsprung disc, as well as the updated transmission with the rubber-damped disc.)
The GM AR5/R154 is a bit easier than the GM AY6/RA62 because the bellhousing is not integral to the transmission case, and so a Toyota bellhousing can easily be swapped onto the GM transmission. That said, you're still forced to use a non-Toyota friction disc, as the input shaft splines are different between the GM transmission and the Toyota transmission. This is also the case for the AY6, the GM version uses a 23-spline input shaft in place of the Toyota 21-spline. Additionally, it is a push-type clutch and uses a pilot bearing with an integrated slave cylinder in place of the pull-type clutch and release-fork with external slave cylinder that Toyota uses on the RA62. In short, don't look to GM for any compatible clutch components for the IS250.
The master cylinder is a 3/4" diameter, and the slave cylinder is a 15/16", which isn't a super common size for Toyota (though they have used those same sizes on other applications like the TRN2## Tacoma).
As I said earlier, the GM AY6 setup uses a very different setup which is a 255 mm 23-spline disc in place of the 236 mm 21-spline disc of the IS250.
It's interesting because GM actually doesn't sell just the clutch disc by itself, you have to get the pressure plate and clutch disc as a kit, which lists for $389.43 (2010-2012 Cadillac CTS and 2010-2015 Camaro, Part No. 19353433). Toyota lists the clutch disc for $86.18 for the original unsprung disc and $116.19 for the rubber damped disc. If you include the pressure plate (Toyota Part No. 31210-53032, lists for $354.74) it's a bit more expensive than GM by $51.49. I'm sure your 10x estimate was a bit of hyperbole, but it's really only 13% more expensive for the Lexus clutch and pressure plate than for the GM clutch and pressure plate (which won't fit anyway).
As for the original poster's question, there are a few options out there for different setups for the IS250 6MT, but not as many as other cars, that's for sure. The only other alternative options I really have to add other than what you've already listed would be the PGEAR FW1224005 flywheel (unfortunately out of stock and requires a minimum qty of 5 to run them due to lack of demand) and possibly going with a larger sprung disc. The flywheel and pressure plate can handle a larger disc up to about 250 mm.
I am running a 250 mm Aisin NVR sprung disc on a PGEAR chromoly flywheel using a higher capacity SPEC pressure plate with no clutch accumulator:
(One other clutch/flywheel setup exists and that is the setup from the GRMN Mark X, which is a stronger version designed to handle the 3.5L's higher output, but it's still a dual mass setup, and very expensive, so probably not worth considering.)
Jeff
Ik I am super late but can you give the part numbers. I want to make sure I found the correct stuff when I looked up the parts. Thanks!
Old Apr 21, 2024 | 08:57 AM
  #34
PAVGR's Avatar
PAVGR
Hey guys.I ve read this thread and I want to ask if someone actually install another clutch kit .My Aisin clutch disc Jeff Lange suggested back then and spec stage 2 clutch is starting sleeping a lot now that I change my tires and I want to now if spec stage 3+ (which is very expensive especially for me from Greece)is the only option.Has anyone tried to install a supra clutch or anything else?There s an idea to reinforce the same spec 2 clutch and disc I already have in a machine shop.A lot of guys do it here .You let your clutchkit and flywheel and say what WHP and torque you are and reinforce the clutch and clutch disc.Has anyone done it?
Old Nov 4, 2025 | 10:19 PM
  #35
Jeff Lange's Avatar
Jeff Lange
Keeping it Real
Yeah, finally talked to some folks and got my mock'n'measure all cleaned up late last night and slept on it.
Mk4 Supra flywheels typically have a .020 bump up (toward the trans/rear of vehicle) from the mounting hardware. The SL25A friction surface is 7.5mm on the nose sunken into the fly. Typical clutch disk thickness is 7.5mm. Additionally, the hardware attaching the friction surface to the SL25A is 100-degree countersunk #10-32tpi hardware. Friction surface OD is 10-3/8", inner hole is 6".
Therefore, a 5/16" thick ring with a buncha transfer-drilled .1935" holes will need to be made. 7.5mm=.2953"; 5/16=.3125"; .3125"-.2953"=.0172. Close enough to .020" proud for me.
Random question, but did you ever end up running the V160/161 pressure plate on the 3GR? It's still been on my mind all these years later.
Jeff
Old Nov 19, 2025 | 01:45 PM
  #36
PCourty's Avatar
PCourty
Hi all, new owner of an IS250 6MT and would you believe it... The clutch needs replacing 😅
I have ordered all parts listed for the SMF conversion (PGear SMF, release bearing, etc) except for one which seems to be very hard to find.
I can't find the DTX-189 (31250-60500) clutch itself, everywhere just says out of stock. Have these been discontinued and is there an alternative clutch that anyone knows of?
My car is currently up on ramps at my yard, waiting for this one part, but I just cannot find on that is in stock 😔
MHowerton1
Oct 5, 2023 07:39 AM
SebaPR
Nov 27, 2015 12:19 PM
bboysunone
Jul 23, 2012 11:55 AM
ihkskim
Apr 11, 2008 11:37 PM
inovashn
May 17, 2005 07:59 AM
