04 GS300 Acceleration issue
Old Oct 21, 2018 | 12:43 AM
ChaseTran's Avatar
ChaseTran
Default 04 GS300 Acceleration issue
When I first press the accelerator, there is a small push, and then no acceleration. After a short time, the car then begins accelerating. The pause gets longer the harder I initially press the accelerator.
My GS has 135k miles on it. recently replaced the harmonic balancer and radiator with aftermarket ones. I put in a K&N Air filter, replaced the spark plugs, all the belts, and the water pump. I'm going to replace the fuel filter soon to eliminate that, but otherwise I cannot for the life of me find what is causing this problem. Any thoughts or suggestions?
Old Oct 21, 2018 | 08:17 AM
JellyBean's Avatar
JellyBean
If the car accelerates fine while on cruise control, then please check the accelerator pedal position sensor. There are a few threads describing similar hesitations that were finally tracked down to faulty APPS units. Good luck!!!!
Old Oct 21, 2018 | 08:40 AM
ChaseTran's Avatar
ChaseTran
I never even thought of this. Thanks man I will definitely check into this and update after.
Old Oct 22, 2018 | 11:17 AM
captainva's Avatar
captainva
Also check if there is slack in your throttle cable. That will help with throttle response too
Old Nov 30, 2018 | 02:24 PM
brainsurge's Avatar
brainsurge
MAF cleaning or replacement has been done?
iSalah
Jul 11, 2018 04:22 PM
PHX-GS430
Performance
79
Jun 19, 2018 04:18 AM
Ontiveros3
Oct 22, 2013 08:05 AM
ki15686
Oct 22, 2011 04:05 AM
brazil
Jul 31, 2009 02:26 PM
