Looking for a Lsd Differential for Is350
Welcome....
There is no drop in solution as we have a crazy 4.083:1 ratio. Your options are to buy an LSD carrier/center section of your choice and have it installed on your ring gear and setup in your case. Mind you your case/housing will need to be modified to accept any LSD even the OEM Torsen from the RC or ISF. Use the search engine and you'll find some posts of mine and others on this topic.
tags:
Torsen, Cusco, OS Giken, ATS Carbon
https://www.clublexus.com/forums/per...sd-thread.html
yotaholic
06-13-15 07:57 AM
