IS 250 Lexus Hit From the Rear
Old Oct 25, 2017 | 06:24 PM
miquoe's Avatar
miquoe
Default IS 250 Lexus Hit From the Rear
I was hit yesterday and the Lexus shut off and the shaft will not move into drive, it moved into neutral. I went back to check and the brake light is on. There is very little damage on the body, however I think it not out something...any one to help!!
Old Oct 26, 2017 | 11:16 AM
Gville350's Avatar
Gville350
Pop out the little square plastic cover on the center console shifting assembly and depress the black piece inside the hole. This allows you to shift through the gears even while off. See if that helps.
Old Oct 26, 2017 | 05:40 PM
miquoe's Avatar
miquoe
Smile Car started but towed to the autonomy shop
Thank you,
They were able to get the car started however is their a shut off reaction when the Lexus is hit from the rear. Michele
Old Nov 7, 2017 | 10:42 AM
juiceman11's Avatar
juiceman11
Hello My 2008 IS250 is running really weird the altenator went out a few days I replaced it now I have codes that keep popping up it shows misfire from Cylinder 1 AND 4 P0301 and P0304 now its P0300 P0020 intake camshaft position Actuator circuit open bank 2
p0201 202 204 205 injector circuit open
P0348 camshaft position Sensor A circuit high input
p0351 ignition Coil A primary secondary circuit
p0353 ignition Coil C primary secondary circuit
p0355 ignition Coil E primary secondary circuit
I don't know where to start or where some of these components are can someone please help
what is the code for faulty computer can someone help me with this
Old Nov 7, 2017 | 05:03 PM
bbaugher47's Avatar
bbaugher47
Hey juiceman. Create a new thread and I’m sure it will garner more traffic so someone can help you out.
Old Nov 8, 2017 | 05:16 AM
jr4div2's Avatar
jr4div2
Originally Posted by miquoe
Thank you,
I don't think there is. I suspect the jolt either knocked the shifter out of sync with the transmission or, if like me, I rest my hand sometimes on the shifter and I could see me doing it. The car may have been moving forward when this occurred and that could have caused some sort of jam up in the transmission.
@juiceman...Very poor etiquette hijacking someone's thread like that. Like you've been told. Make your own thread.
Old Nov 17, 2017 | 04:57 PM
miquoe's Avatar
miquoe
Question Lexus Accident
They now replaced the bumper and I need a new trunk hood do you think there is undercoverage damage as well? Michele
NIAautoDesign
CL Vendor Products for 3IS
Feb 26, 2018 11:38 AM
netinfant
Oct 20, 2015 04:41 PM
ktt901s
Great Lakes
Feb 25, 2009 12:45 PM
TOPSPEED
May 24, 2001 05:39 PM
