Lexus F sport Intake
Old Sep 28, 2017 | 06:18 PM
KevnGarvey's Avatar
KevnGarvey
Default Lexus F sport Intake
So I emailed a dealership that sells on Ebay and they said that there is no sold separately lower intake box. I was looking for the lower intake box (F-Sport), you know the one with TWO square holes in it. The dealership said Lexus only sells the upper cover of the box, filter, and tube. The dealership said that you use whatever lower box you already have. I am curious then which model Lexus 3IS F sport has the extra square hole in the front of the box. I check my box and it is the one with only one square hole that leads to the opening in the front of the hood.
If it doesnt matter about that extra hole then what is the whole point of even changing to the F sport filter and tube?
Old Sep 29, 2017 | 12:28 AM
specONE's Avatar
specONE
3IS only upper airbox lid.
What you've seen with the hole in lower box is 2IS specific.
2IS got lower box and kept stock top lit, total opposite of 3IS setup
Old Sep 29, 2017 | 07:59 AM
KevnGarvey's Avatar
KevnGarvey
https://youtu.be/yK0BI7UgCj8
thanks! I was very curious why I only see the top lid for 3IS. What are your thoughts on which one is louder (3Is f sport intake or oem with sound generator)? Also is there any gain from the f sport intake on 3Is?
Old Sep 29, 2017 | 09:58 AM
specONE's Avatar
specONE
3IS intake is not loud at all, in fact its more quieter than the stock 3IS intake =
the reason for this is the sound generator on the stock plastic pipe is gone on the Fsport metal pipe.
the 2IS is most likely louder due to the hole in the lower box.
I have considered cutting a hole in my stock box to gain the noise but have not in fear of losing performance.
Aftermarket intakes like Takeda etc supposedly makes the car slower in response but create a lot of noise. You are robbed of performance with these in exchange of alot of low grunt noise, This is what tuners typical are stating they are seeing on the dyno. I will just relay this information and you take it how you wish.
Old Oct 4, 2017 | 09:23 AM
evltwn's Avatar
evltwn
I went with HPS intake pipe because it kept the sound generator for the FSport cars. I used the stock box, and just cut out a hole in the lower portion that faces forward. I just bought the FSport drop-in filter, and it's kinda like a poor mans FSport Intake.
Old Oct 4, 2017 | 02:25 PM
TJR14IS350's Avatar
TJR14IS350
Thats exactly what I did. But I used a k&n filter because I got it cheap. Works perfectly. Sounds awesome paired with my apexi mid pipes and Stillen axle back.
Old Oct 4, 2017 | 03:22 PM
specONE's Avatar
specONE
Be careful, make sure the K&N filter is the dry type and not oiled ones.
The oil can mess up MAF sensors.
Old Oct 4, 2017 | 04:28 PM
TJR14IS350's Avatar
TJR14IS350
lol its oiled but it's been installed on the car for for 8 months no problem haha.
Old Oct 7, 2017 | 10:13 PM
LexoDAV's Avatar
LexoDAV
buy the 2is air box system and use the lower f sport air box. There's a lot of used air box out there. The 2 gen f sport air box will be better in sound and performance. I have the 3is f sport box and it did t do anything at all maybe 2-3 hp
Old Oct 7, 2017 | 10:53 PM
minhael's Avatar
minhael
I consider that before and spec one save me some money cause i cancelled it right away. The 2nd gen box will not fit the 3rd. So it's not an option.
Old Nov 29, 2017 | 11:12 AM
Jbreezie's Avatar
Jbreezie
How do you like your setup? Feel the difference? Post a pix! I just purchased the HPS intake! I will probably do the same! I have the Fsport filter as well.
Old Dec 5, 2017 | 10:17 AM
BRiCCFLAiR's Avatar
BRiCCFLAiR
I can't seem to find an F Sport intake for my 2015 IS250. Are the 2014 p# compatible?
Old Dec 5, 2017 | 10:25 AM
specONE's Avatar
specONE
Yes the same part numbers apply for 2014-2017+PTR03-53141
http://ebay.to/2jfJn3Z
Old Dec 6, 2017 | 11:36 PM
evltwn's Avatar
evltwn
I don't really feel too much of a difference. The HP you might gain is so small, that you won't feel it. That being said, I have no regrets doing it.
Old Dec 7, 2017 | 10:00 AM
BRiCCFLAiR's Avatar
BRiCCFLAiR
Wow, the F Sport blue engine cover is a nice touch!
