okada plasma direct ignition coils
Old 09-03-17, 07:31 AM
NoneSoVile
NoneSoVile's Avatar
Default okada plasma direct ignition coils
does anyone have any experience with these? saw them and im considering pulling the trigger on them, considering that someone in here has some good things to say...
Old 09-03-17, 07:12 PM
Gville350
Gville350's Avatar
Purchase PPE headers instead. More power and new lovely sound! I've purchased similar upgraded coil packs, and because I installed them along with my PPE headers I cannot point to anything specific that they might have helped with. But I purchased Accel coil packs; definitely different, but there's only so much output a single spark plug can yield.
Old 09-24-17, 11:46 AM
2013FSport
2013FSport's Avatar
Received 1,484 Likes on 1,238 Posts
The thing is the ECU output is matched to the coils so changing the coils energy output only results in loading the ignition circuit more which often times means increased heat. Think in terms of matching an amps output to its speakers and wattage. The amps output impedance is set to the load it sees. That said the ignition output is not easily changed and coils are ohms, inductance (henry's) and capacitance. All must match and balance each other out.
When we left the erra of points and condensors towards capacitive discharge where dwell duration is managed electronically, it was a huge step. So unless you can engineer to a higher level than Master Yoda, I'd leave it alone for reliability reasons.
Old 09-24-17, 04:25 PM
NoneSoVile
NoneSoVile's Avatar
Thank you both very much! Looks like it's the RR tune + headers package for me!
05ls430518
03-05-18 05:23 AM
Katlexus
03-28-17 06:04 AM
gserrano80
05-31-16 03:50 PM
jaymil31
SC- 1st Gen (1992-2000)
05-06-16 09:30 AM
Gville350
Performance
15
01-14-16 01:44 PM
Quick Reply: okada plasma direct ignition coils
