IS250 MT: Fidanza Lightweight Flywheel and Spec Stage 2 Clutch Review
#77
Hey guys, I was trying to browse this thread to figure what I should do about my current clutch & flywheel situation. I have a 2007 is250 MT RWD. My clutch is completely worn out & I'm not sure of the condition of my flywheel. I've purchased an Aisin OEM replacement (unsprung) clutch kit but I wanted to avoid spending $2k on a replacement dual mass flywheel if it turns out that it needs to be replaced. I saw that Fidanza & Spec had some single mass flywheel options for a large price difference. I saw some things about changing from dual mass to single flywheel, but I would like to know will I run into any issues with replacing my clutch, with an Aisin unsprung OEM option with a Fidanza or Spec single mass flywheel. I tried to reach out to Fidanza directly but haven't heard anything back yet. Any helpful advice would really help me out. Thanks
#78
To your specific question, you shouldn't have to replace your flywheel. It's a tank and designed to last pretty much forever, so I wouldn't worry about it. If you want to install the unsprung kit, go ahead, but I believe it will feel heavier and more abrupt.
I just saw a PM sent two years ago from another owner who tried out this install too. He ended up going back to the OEM setup because he hated it.
#79
To be honest, the Fidanza flywheel and unsprung clutch replacement completely destroyed my car and made it undrivable. I don't know if it's because my mechanic installed it incorrectly, but the clutch was completely worn out by the time I traded the car in. And I got rid of the car in months, not years, after the change. The sad reality is that the IS250 has a Tacoma transmission. Nothing is going to change the fact that it feels clunky. If I had to do it all again, I would just get OEM parts and not try to make any modifications.
Firstly, I ended up replacing both because I had the issue where I had a fairly loud chatter during idle (clutch not depressed) and it was starting to get embarrassing at stop lights which I've read in other forums that it could be a multitude of things such as pilot bearing, release bearing, input shaft bearing etc. Although my clutch was not slipping at all, I figured it was time to upgrade the system anyways at 190,000km. I was wary about the overall lifespan of the clutch/flywheel system. I'm still in the break-in period but here are my thoughts:
- I do have chatter around 2000-2200rpm like a few others in thread
- It's very hard to get into first, third to fourth and fifth to six. I really don't want to believe that my syncro's are shot simply because of a clutch/flywheel replacement and I'll comment more about this 1000km's time.
- If this clutch is going to only last a few months then I definitely made the wrong choice (and a very expensive one at that) I would classify myself as a fairly conservative driver.
You're right about it being a Tacoma transmission and no amount of modifications to the clutch or flywheel will make it feel like a compact luxury sedan. Having the last of the manual Lexus cars is now a love/hate relationship.
DaveGS4 (09-19-19)
#80
I just wanted to chime in on this topic since I just got this setup installed not too long ago. I've read this thread a few times before making my decision on buying the Fidanza flywheel and Spec D stage 1 (rigid disc) clutch kit.
Hi all ill throw in what I did when my clutch was ready to be changed about 4 years ago now, I just got the F sport clutch, and its been pretty good besides sometimes when I downshift it does a bit of a weird grind, it doesnt happen often so I live with it. Got 226000 km on it now and its good
