Tapping Oil Pan on GS400
Old Jul 5, 2011 | 10:53 AM
vwynn's Avatar
vwynn
Question Tapping Oil Pan on GS400
1) Question about this matter, whats the best way to tap the pan? better yet, whats the best way to tap for oil drain?
2). regarding the oil pan. Is it a simple unbolt and drop? (with the needed cutting of the gasket)
3). where is the best place to tap? which of the corners, how high? (dont really know where the oil level is at )
4). where is the better place to tap for oil? Sandwhich plate or Oil Sensor?
or suggestions
Thanks!
Old Jul 6, 2011 | 08:21 AM
vwynn's Avatar
vwynn
guess not a lot of GS400 owners dont really do this :/
Old Aug 15, 2011 | 06:39 PM
LALEX1's Avatar
LALEX1
bump. I am in need of this info as well.
I know there are members that have done this before.
Old Aug 15, 2011 | 08:45 PM
vwynn's Avatar
vwynn
Yes. please someone share some info. mainly where is the most optimal place to tap at... for the drain hose.
Old Aug 16, 2011 | 12:44 AM
GS4_Fiend's Avatar
GS4_Fiend
Well, it's like any other pans. Get a tap and dye set and tap it out. It's most recommend that you do not use a too big or a drain plug or else you might ending up cracking the the pan. In cases like this, it's a 50/50 chance, either you succeed without dripping oil or you just fail, in worse case buy a used oil pan.
joaqin
GX - 1st Gen (2003-2009)
Jan 30, 2016 07:21 PM
Golden95SC
May 31, 2015 07:34 PM
TwoForDee1
Feb 15, 2014 11:22 AM
SynicalVip
Apr 9, 2013 02:42 PM
