I will shortly be getting the TT rear end installed. The Auto TT 3.76 rear end. There has been some talk about a trans ecu to adjust the rev limiter. Any progress on this or am I going to have to look into having one made msyelf?
thank you
IMO this is really a question you should post in the SRT section as they're the only ones that are working on this to my knowledge.
I'd also recommend you give Mo a call personally to discuss their progress on the mod, because SRT doesn't often give updates on 'expected release dates' for anything - they just tell you when they're done with it.
Originally posted by Pearlpower I will shortly be getting the TT rear end installed. The Auto TT 3.76 rear end. There has been some talk about a trans ecu to adjust the rev limiter. Any progress on this or am I going to have to look into having one made msyelf?
thank you
I also have the 3.76 unit install, alonmg with the TC, and 19" Lowenhart BR5s, and I only hit the rev limiter when I am in e-shift; never do I hit it under WOT. Kisses the red line, but not the rev limiter.
Same here... Ive got the 376's SupraTT rear end also. Ive heard about this happening many times but have never had it happen to me....
