what does everyone have their tire psi set at?
02-14-11, 06:18 PM
Just wondering what everyone uses as their psi for the tires? I live in NY. Mechanics out herealways set mine at 32. Just wondering what everyone uses and what the oem recommends.
02-14-11, 06:34 PM
I have my at 35psi. But it all depends on the tire you have.
02-14-11, 06:45 PM
LOL. Please Be Specific.
like others said ! depend on the tires.
Slow Cuz It's Low
02-14-11, 07:55 PM
for regular car. 32
i run 45-50 tho
02-15-11, 03:17 AM
I run 50psi lol most people don't understand why so high, but no bubbles on my tires so far
02-15-11, 06:02 AM
Since this is a thread on PSI....
What's the difference between lower/higher PSI? What are the advantages/disadvantages?
02-15-11, 09:08 AM
front 235-45-17 ==> 32 psi
rear 275-40-17 ==> 33 psi
02-15-11, 09:10 AM
Quote:
Originally Posted by
LuxuryGS3
Higher PSI
Pros: Better gas mileage
Cons: Slightly harsher ride
Lower PSI
Pros: Cushier ride
Cons: Worse gas mileage
02-15-11, 09:20 AM
i set mine with nitrogen about 32-34 PSI in the summer and bout 38-40 PSI in the winter and then check every 3 gas fill ups
02-15-11, 10:15 AM
I run 40 psi on a 51 psi max tire.
02-15-11, 10:32 AM
ThomasGS4
Higher PSI
Lower PSI
Pros: Cushier ride
Thanks Parker.
02-15-11, 10:45 AM
I run 35-40 Psi gas mileage is good..full tank last two weeks, but then again its a short drive to work
02-15-11, 11:14 AM
sakataj
Now that I got to do (i.e check tire pressure regularly)... Is there a difference with regular air and nitrogen ?
34 front -225/35/20
36 rear -225/35/20
02-15-11, 11:16 AM
They claim with Nitrogen, you get better performance on the tires and it doesn't lose air as much air as you would with a regular air inflation.
02-15-11, 04:42 PM
dont pump too much with ur regular tires.
it balloons and makes the middle of the tire wear faster than outsides
