Stock ECU swap worth it? '04 --> '98
Old Jan 31, 2010 | 05:48 PM
Frankdorn's Avatar
Frankdorn
Default Stock ECU swap worth it? '04 --> '98
I've been searching for about a half hour...still not sure if I know the answer...
An acquaintenance has an '04 GS300 -- does he have the upgraded steering ECU?
I have a '98 GS400 -- is it worth my time to give him some cash to swap ECUs? Will they work in each others' cars?
Old Jan 31, 2010 | 05:55 PM
kit cat's Avatar
kit cat
depends on how much and I wouldn't do it personally with someone you know just in case they complain later.
and before any noob asks what a steering ECU is, go search.
Old Jan 31, 2010 | 06:03 PM
jcat_350's Avatar
jcat_350
no, they will not. if it was 300 to 300, or 400 to 400, or 430 to 430, yes. But, going from a 300 to a 400 is a no go.
Old Feb 1, 2010 | 04:31 AM
KiPod's Avatar
KiPod
If you are talking about the steering ECU's then yes they will swap just fine. All 300, 400, & 430 steering ecu's can be interchanged. Get one from later than Jan 02 (300 & 430 are the same) or even a SportDesign.
Old Feb 1, 2010 | 05:33 AM
Frankdorn's Avatar
Frankdorn
Thanks, KiPod, I was hoping you'd respond...you seem to know your stuff about this. I'll give 'er a shot!
Old Feb 1, 2010 | 08:53 AM
KiPod's Avatar
KiPod
No problem. I did a lot of research too & went with a SD ecu myself. I didn't really notice a dfference all the time. The highway is where I mainly noticed a difference. Nothing major, but better.
Old Feb 1, 2010 | 11:35 AM
jcat_350's Avatar
jcat_350
oh...by your thread title it sounded like you wanted to swap actual engine control units...not steering control computer....if that's the case then certainly yes steering controllers can be swapped...engine controllers however cannot.
Robnh
Feb 7, 2019 01:02 PM
r2k247
Jun 4, 2006 11:37 AM
IceMan530
May 23, 2006 01:13 AM
ji09051
Feb 28, 2006 07:08 AM
lv2000
Performance
Nov 9, 2002 06:55 PM
