Single turbo setup for GS400?
Old Nov 5, 2009 | 05:17 AM
Clifton's Avatar
Clifton
I've turboed quite a few cars and two trucks that never came with a factory option. I hope I don't come across as too much of a ****, it's not my intention really but if you have to ask you shouldn't do it. Read as much as you can. Not just on this board. You will learn more about tuning on other sites. What starts out with a few psi will turn to power greed. AFR, timing, compressor maps, ect are just the basics of DIY. Then as someone else mentioned the trans. I know this is a Lexus board but I would look into a 03-05 E55. Super charged 5.4, crazy torque and bullet proof trans, plus big brakes.
Old Nov 5, 2009 | 08:03 AM
DumpedGS's Avatar
DumpedGS
yea the more and more i look at it, the more the procharger/fish2 route apeals to me. figuring out what to do with the windshield wiper bottle is less of a PITA than building turbo manifolds lol
Old Nov 5, 2009 | 08:43 AM
speedaddic's Avatar
speedaddic
that turbo LS looks good but man o man do I hate FMU's. They are so 1990's with all the technology we have these days. I ran the Cartech FMU and had issues under 2k miles of use.
Old Nov 5, 2009 | 08:51 AM
kit cat's Avatar
kit cat
There's a guy here in Chicago with a JZA80 Supra with a non-VVTi 1UZ single turbo.
Old Nov 5, 2009 | 11:37 AM
DumpedGS's Avatar
DumpedGS
agreed. since the advent of the SAFC, there is NO reason to ever run an fmu.
Old Nov 5, 2009 | 01:45 PM
speedaddic's Avatar
speedaddic
I was thinking more of the AEM FI/C 8 though, controls ignition as well as injectors
Old Nov 5, 2009 | 04:26 PM
JBrady's Avatar
JBrady
Certainly the HARDEST thing about FI is the ability to correctly tune the air/fuel ratio AND the ignition timing.
The Cartech FMU does a reasonable mechanical job on cars with return fuel systems. The SAFC and tuning devices like it mearly adjust the MAF signal causing a change to the fuel map. Problem is the stock ECU will try to correct the "modification".
IFAIK no one makes a device that allows the stock ECU to be modified or tuned internally. Shame. It would be usefull to have an interceptor type device that takes the stock sensor signals and modifies them causing the stock ECU to make the changes needed. Until we have something like this we will be limited to low boost applications that can be tuned with SAFC type devices or go with a complete stand alone which creates a whole bag of new problems.
I am still thinking about a SMALL pair of turbos mounted low at the stock manifold outlet position. 3-5psi boost run efficiently is 20-60+% power increase.
Old Nov 5, 2009 | 08:31 PM
speedaddic's Avatar
speedaddic
yea...too bad we don't have somebody that can hack the ECU maps. It was so easy turbocharging my silverado with the tuning capability of the hypertuner
Old Nov 5, 2009 | 08:56 PM
FinLIFE's Avatar
FinLIFE
http://mahdavimotorsports.com/produc...0_turbo_v3.htm
Old Nov 5, 2009 | 09:03 PM
speedaddic's Avatar
speedaddic
yea, that 17psi is a misprint. I talked to them a month ago about that...lol
Old Nov 6, 2009 | 10:44 AM
DumpedGS's Avatar
DumpedGS
i keep reading that all over this forum, but have yet to experience that myself. i street tuned my 98 gs400 with an innovate lm-1 (2 bungs welded into each pipe after cat) to an afr of 13.3-13.5 @ WOT using an safc-II. my afr's are rock solid after driving on it for 3 months now, and even after my battery died and i installed a new one. under WOT conditions i think its safe to say the ecu does not try to re-learn. (goes to preset maps) under part throttle conditions, the ecu maintains a steady 14.7 afr....which most deffienetly is a learning condition.
im not sure what would happen under boost though...i would ***-u-me, that if the setup was making boost at a part throttle condition, the ecu would still achieve a 14.7 afr, which we all know is bad news. at WOT the safc is more than adequate. im not sure how the ecu would react under boost as this is the 1st maf car ive ever owned....that part is still a mystery to me.
Old Nov 10, 2009 | 09:59 AM
DumpedGS's Avatar
DumpedGS
hmmm after reading morris's entire build thread, i think im back onto the single turbo bandwagon lol just need to find myself a beater daily driver so i can get started on the fab work.
Old Nov 10, 2009 | 10:06 AM
LexFather
Guest
Posts: n/a
I've ridden in Morris and Jaime's single turbos....wow!!! Never thought a V-8 GS could get that fast and powerful
Old Nov 10, 2009 | 12:00 PM
Rock-a-Lex's Avatar
Rock-a-Lex
I have seen youtube videos of Jaime running at the track. It is a a fast car but I was surprised to see he was only getting 13.2's in the 1/4 mile. Figuring if he had 400whp (500hp crank) I would think it would do better than that. Maybe something was up with his tune that day?
Old Nov 10, 2009 | 02:27 PM
DumpedGS's Avatar
DumpedGS
traction and banging the rev limiter on the 3-4 shift was the problems (at least thats what he says in morris' thread) said he had to lift, let it shift, then get back on it....13.2 @ 108 (fyi 108 is mid to low 12 no problem)
