Missfire but no CEL code??
Old Mar 5, 2009 | 06:04 AM
Emil's Avatar
Emil
Default Missfire but no CEL code??
Had my plugs changed for some NGK IFR6T11 plugs last week,and since then i've got a really bad missfire.
The CEL code is up,along with TSC lights,but there is no CEL code from the OBDII reader in the dashboard?
Can i manually check with engine light flasing by connecting a paper clip with TC and E1 in the engine bay?
My GS is an early '01 model,where there was a change over apparently.
Car was running perfect before,i've got a 2nd hand set of coils/leads,and after changing no6 coil,it is better but still there under idle and throttle.
Don't think it's plugs,as misfire only appears once car is warm,not there when cold
Thanks
Old Mar 5, 2009 | 12:39 PM
Debonair's Avatar
Debonair
What scan tool are you using? Some better/enhanced scanners offer "History Codes" in addition to current codes. Check there.
Generic OBDII scanners usually do not offer this.
Old Mar 5, 2009 | 12:45 PM
Debonair's Avatar
Debonair
I just noticed that you said the VSC light is on too. The main MIL (Malfunction Indicator Lamp) can also come on when there is a code stored in the VSC system as well. A generic ODBII scanner will not access the VSC to get you this code either. You need to hook up to a better scan tool.
Old Mar 6, 2009 | 12:27 PM
Emil's Avatar
Emil
thank you for the reply mate,will get this looked into asap
Old Mar 6, 2009 | 12:36 PM
Debonair's Avatar
Debonair
No problem.
bwhitsonjr
Feb 19, 2019 04:29 PM
WainiacS
RX - 1st Gen (1999-2003)
Nov 28, 2011 07:04 AM
CallmeQ
GS - 1st Gen (1993-1997)
Sep 26, 2009 12:19 PM
StiCk3
Apr 26, 2008 05:40 AM
j.tom
Sep 7, 2007 05:15 PM
