Boosting on a high milage GS300 ?
Old Nov 9, 2007 | 10:48 PM
GS_OREO's Avatar
GS_OREO
Default Boosting on a high milage GS300 ?
My 98 GS300 has 130k on the clock, and I just ran into my buddy who can get me turbo kits for a killer deal. My question is, does my block have enough life left to withstand a turbo running at low boost, we'll just say 6-7lb's ?
My block is totally stock, stock headgasket, etc.. Not planning to go overkill on my setup. I just want a lil extra power.
Old Nov 10, 2007 | 04:24 PM
LCSC's Avatar
LCSC
130k that brand new in my book.
Old Nov 10, 2007 | 04:44 PM
GSteg's Avatar
GSteg
the engine will laugh at 6psi
Lexizm's Avatar
Lexizm
If I were in your shoes and I have been, I would go get a compression test first to make sure your motor is strong enough. You will know from the results of the test where you are and what you need to do to get there.
Old Nov 10, 2007 | 07:48 PM
edro925's Avatar
edro925
Yup tells you how well your rings or head gaskets are. I dont know what kind of head gaskets toyotas has but if its cometics your in good hands. Someone correct me if i'm wrong.
Old Nov 10, 2007 | 07:56 PM
macd7919's Avatar
macd7919
You should be fine to run 5-6psi on a stock motor, I wouldn't go any higher than that though, not with a stock head gasket. If you want go higher than 6psi on a stock motor you need to lower the compression via a thicker head gasket. Also, I'm assuming you plan on doing this anyways but you will need an intercooler, some of the older/budget setups run without an intercooler but it really limits your boost to just a few pounds.
Old Nov 12, 2007 | 09:13 AM
ElitistK's Avatar
ElitistK
might as well take the head off, put in a 1.3mm HG and do some head work while you're at it. i would lower the compression before doing any kind of FI with the ge
dminah21
Oct 3, 2018 10:23 AM
clarky0
Jan 11, 2013 08:05 PM
j0xxx
Performance
Jan 21, 2007 08:53 PM
stsleeper9
Nov 1, 2006 10:19 AM
treimche
Performance
25
Oct 31, 2006 03:45 PM
