Fabulous Inferno Oval Muffler
i'll keep you all posted
If its the oem "donut" gasket that attaches to the oem resonator, then it should work with out any problems..
If the shop is talking about the other gaskets that connect from the pipes to the muffler sections than you'll have an issue if they are missing..
It all depends which gasket your shop thinks is missing..
Jz
I like the fact that the exhaust tips work like a clamp, so I could tug them in or stick them out all i want
However the kit did not align properly, the passenger side tip is few mm's away from the bumper while the tip on the driver side is not 100% horizontal. Will the bumper eventually melt?
I took a picture with my phone for reference, the OEM exhaust system is a single piece as you can see next to the car, not 3 pieces like the Fabulous. Btw, so far the exhaust sounds good, a lil too drowny on the 1,500-2,000 RPM range and not a lot different than the stock at high RPMs. That's not what i usually go for but i like it. Keep in mind that my car has the 3.0 3GR-FE engine with lower compression ratio than the X50's so it might sound better on your cars
dont wait till uve damaged the pipes, see wat u can do to get them fixed as soon as possible.
MAN lexus just makes doing any type of mods to our car hell. The simplest mods cause headaches
on a brighter note; let us know how does it sound? feel any diff in power?
) i might get the pipes custom made at a later stage and make the most out of it: - real dual system
- X-pipes
- increase ground clearance
- fix the alignment
- whatever might come up next!
verdict: my car has reached puberty! i like
QUOTE=kattanh3;3084394] no difference in power can be felt. the car is much louder, it's too drowny between 1,250 & 2,750 RMP but very smooth after that (just what i need for city / highway use), it does it in a non-civicy way, the exhaust has only 30-ish km on them so far, it yet has to burn-in properly to get the final exhaust tone.
[/QUOTE]man u got to post some sound clips or video slips up, with a name like inferno the exhaust sound must be badass
mabrouk again
