The K&N filter for their IS350 intake is part #RU-4990, which has a 3" diameter opening, and is probably the one LMS uses. Measure the diameter of your LMS intake tube and compare it to make sure it's the same size. If it's not, then you can find one of a different size here.
Great opportunity to switch out to a Dry Filter... (non-oiled)
just a thought...
Yep yep..... time to swtich to a dry filter, just measure the opening and the length and if you want to stay with a k&n go to pepboys and they should have something.
