Valve spring upgrade why?
Old May 29, 2007 | 06:56 PM
morris's Avatar
morris
Default Valve spring upgrade why?
When and why do you upgrade the valve springs on your heads?
Old May 29, 2007 | 08:03 PM
Jrezo's Avatar
Jrezo
Usually when you get cams then you would upgrade depending on the new cam lift specs.
Old May 29, 2007 | 08:17 PM
GSteg's Avatar
GSteg
And/or for those who are revving way higher than OEM redline. Try revving to 9000 RPM on our V8s (example here, dont take it too seriously). You're probably going to experience some valve float. Stiffer springs may help overcome this but you will be increasing friction between the camshaft and the valve springs.
geoleo
Dec 12, 2017 06:51 AM
mac777bos
Nov 8, 2014 09:16 AM
kinch09
Mar 29, 2013 06:08 PM
WhitSoarer
Mar 7, 2010 12:06 PM
VQT
May 30, 2002 08:43 AM
