View Poll Results: Supercharge or Turbocharge
Supercharge
32.56%
Turbocharge
67.44%
Voters: 86. You may not vote on this poll
Supercharger vs. Turbocharger
Old Jun 16, 2008 | 03:12 PM
  #31
pvmike1's Avatar
pvmike1
This poll is useless without specifying the car, power goals, and type of usage.
Also, there are hybrid designs, such as the Rotrex supercharger, that is like a turbo on the compressor side.
Old Jun 16, 2008 | 07:05 PM
  #32
jriggs's Avatar
jriggs
i guess i'm one of the few who would like to find a supercharger kit for the gs300. simple just a few things to bolt on and i'm not wanting a ton more power just a little bit
Old Jun 16, 2008 | 07:26 PM
  #33
morris's Avatar
morris
Dave is the only person I ever met that started out moderate and didnt loose his mind in the quest for more power.
Good luck oh and I have seen GS300's on the board with centrifugul SC's, so they do exist.
Old Jun 16, 2008 | 07:30 PM
  #34
GS FONZy's Avatar
GS FONZy
Finally, someone that understand the application diffrerences over just throwing things they heard or myths around.
Still have yet to see a turbo dragsster break 6s. Long ways to go before top fuel gives up there supercharged set ups
Originally Posted by GSFREAK74
where or who carries a sc kit for the gs300?
Originally Posted by Silver GS
Who carries a turbo kit for the GS300?
you guys really need to use the search option.
Old Jun 16, 2008 | 07:33 PM
  #35
aristo2369's Avatar
aristo2369
Default turbo
Turbo all the way from 9psi to 14psi that all i would need on a gs 400.
Old Jun 18, 2008 | 07:04 AM
  #36
Clifton's Avatar
Clifton
I prefer turbos but they do use power to make boost. They are a restriction though. You need a pressure drop across the turbine wheel. Anything considered streetable will be higher than 1.1 on the turbine side. Even with no back pressure after the turbo you will see 1 psi backpressure before the turbo for 1 psi compressor outlet pressure. I've run some larger turbo with alot of lag and have yet to get below 1.1. The turbo I run now would be considered laggy and is is almost 1.5:1. I don't know what the extra back pressure uses in terms of power but it does cost power to run a turbo.
Old Jul 14, 2008 | 09:00 AM
  #37
Fat Felix's Avatar
Fat Felix
Turbo's definitely have the potential to put more stress on a motor.
Assume both motors are in same condition, used in the same way and both hit max boost of 6psi. Since superchargers are driven by the crank, boost is dependent on crank speed. This means that you'll have to be at the top of your rev range to produce max boost. Depending on turbo size, tuning, etc, max boost from am turbocharged setup can be achieved at a much lower rpm. So you would be able to experience your max boost of 6psi for a lot longer in a turbo setup than a supercharger setup and therefore inducing more stress on your motor.
The ability of this extra stress is why i <3 turbo.
Old Jul 17, 2008 | 06:29 AM
  #38
DarKnight's Avatar
DarKnight
Originally Posted by morris
freight train pull feeling that a supercharger gives VS the rubber band slingshot feel of the turbo.
That's a good way to put it, not that I would know.
Old Jul 19, 2008 | 05:36 PM
  #39
3UZFTE's Avatar
3UZFTE
They are both awesome!
Supercharer...
Give it about a minute, but the intro is a bit long, but WELL WORTH IT!!
http://youtube.com/watch?v=rQW-V6qc-jE
Turbo...
This is one of my favorite videos, he even spins the tires on the dyno..
http://youtube.com/watch?v=0lzqI7wvZvU
Old Jul 19, 2008 | 11:02 PM
  #40
ElitistK's Avatar
ElitistK
or go on another forum.
Old Jul 25, 2008 | 09:11 PM
  #41
GS FONZy's Avatar
GS FONZy
So not true and actually the opposite.
Old Jul 25, 2008 | 09:32 PM
  #42
morris's Avatar
morris
yea definitely not true (speaking from first hand experience)
Old Jul 26, 2008 | 07:44 AM
  #43
GS430V8's Avatar
GS430V8
i would have to say Supercharger
Old Mar 12, 2009 | 09:25 AM
  #44
black_gs99's Avatar
black_gs99
well i had a superchager and turbo on my GS and i would have to say i like the turbo better...
Old Mar 12, 2009 | 02:43 PM
  #45
vwynn's Avatar
vwynn
Superchargers are perdy fun... i kinda like mine right now.. to bad its not boosting much =/
