HELP, opinion needed, FI issues
I would look at the engine management or fuel system. What does the LMS kit consist of? Larger injectors? Maybe they are faulty or of the wrong impedance? Maybe the injector driver in the ecu has gotten fried and the injectors are static.
When you put the other motor in, you didnt fix the problem. The shop that can design and install such a kit should be aware of these points..
This iManage unit actually sounds just like my method of making an SAFC2 switch maps based on manifold pressure, instead of Throttle position, except it is contained in one unit.. with blinky lights.
Any word on checking out the oil for gas fumes from over fueling?
Now, as for an update, i have given them an oportunity to fix the problem and rectify the situation, and they didn't have a problem doing that, at MY cost, buying another new motor. They want nothing to do with accepting any part of it, even the tuning. So, i took the car out of that shop, had a Toyota specialst diagnose the problem, and he documented that he thought the ring was blown, along wth 3 of the coils, and mabe an injector or 2. I then brought it to another independent shop that specializes in FI, toyota drag race cars, etc. They will actually take the motor apart and pinpoint the actual cause of the damage. Why did i do it that way? I needed 2 opinions from shops that I did not know personally, so that if and when this goes to court, I have neutral diagnosis so that it doesnt look like i'm lying. As of now, they are starting on the work and i'll be sure to update you as i get more info.
I know this is REALLY long now, but as a closing comment, I wanted to say that I fully understand that what is said here affects shops all the time. agree wth some previous comments, if there were no problems, we would not post negative, if there are problems and the shop wipes thier hands of it regardless of what the problem could be, then we will tell it like it happened. I haven't made any of this up, and it's all documented. So if anyone is worried about the image of a shop, it's really up to the shop to produce products and services that keep that image clean. It's not like I go around picking shops to bash just because i'm bored. It's not fun for me to drive 5 hours each way every time i have to deal with this issue, so why should I protect the shops image so they can contnue to do this to others? Not gonna happen. I'm glad there are good products from this shop, but mine isn't one of them and it is not my fault.
Peace.
JPI
I had looked into the XFC but i didn't find alot of info on it. If you have any additional info you would like to share, please PM it to me.
(dont want to jack the thread)
thanks...
JPI
JPI
Is'nt the XFC a deadhead fuel system also? On their site it looks like it uses an extra fuel pump for fuel management..
