TANABE INSTALL HELP>>>>PLEASE
Old Jun 1, 2006 | 07:06 PM
Dj Rando's Avatar
Dj Rando
Default TANABE INSTALL HELP>>>>PLEASE
Can anyone tell me any tips on how to remove the stock exhaust from the hanger by the junction ? \
And also how to undo the bolts? I gave it my all laying under the car, and they wont budge at all? Any advice would be greatly appriciated
Old Jun 1, 2006 | 07:17 PM
conekiller's Avatar
conekiller
lube the hell out of the rubber hanger...the exhaust should slide right out.
al503's Avatar
al503
On the rubber hanger, try to squeeze a little grease or oil into slot and work it in. You'll have to jimmy it back and forth to work it in but it will eventually.
On the bolt, is the bolt spinning or just not budging at all? If it's not budging, then you might squirt a little WD40 in to the threads and see if that breaks it up. I have a feeling that you have a small socket wrench that you can't get too much torque with. If you have an empty pipe that will fit over the handle of the wrench, use it to multiply your torque. It will give.
Old Jun 2, 2006 | 07:17 AM
G35TOIS350's Avatar
G35TOIS350
We used a long pry bar type thing to pull the exhaust away from the rubber hanger. You can get them from Auto Zone. Leverage is the key. We used a cordless drill with a socket attachment to get the spring bolts out. No biggie, could have done it with a socket wrench but the cordless was faster. I did have it easy using my friends lift too.
Old Jun 2, 2006 | 08:10 AM
uschardcor's Avatar
uschardcor
crowbar and 10 friends should work
Danais350
Performance
Jan 19, 2016 09:33 PM
Kybball#1
Performance
Sep 4, 2009 12:23 AM
mjf
Performance
14
May 11, 2008 04:11 PM
diablodude
Performance
Jul 12, 2007 06:44 PM
isam250
Apr 6, 2007 08:39 PM
