check engine, vsc, vsc off lights, came on
Originally Posted by Benjamin T
can someone please post the part number? i've been just diagnosed for the same failure
one of my local toyota dealers is offering good prices on oem parts, but cannot cross reference the lexus numbers to confirm, and my lexus dealer of course will not help.
so this means i shouldn't tap and stomp my pedal anymore eh? booo, i like the sound it makes with that SRT intake... and borla exhausts... maybe i should add in headersss... hmmmmm....
Same problem yesterday. Right off the freeway at the stop light, no throttle response at all but the engine was running. Everything was working fine, i could only roll to the closest parking lot. I felt so lucky, I was really just got off the freeway for 30secs. Shut off the car, fire it up again, I could rev it again. CEL, VSC, VSC OFF were on, I didnt think it was a good idea to drive back home, since I didnt know what was going on, and I was 40miles away from home. Went to the closet stealer to have to them check out the problem, they wanted 389 OTD. Got the car back this morning, and just searched here.... I GOT ROBBED!!! I could totally DIY at home with the parts, $100.XX for the part and save 289 for the damn labor towards to my project car fund
Oh yeah...I should stop ******* my car...... But we all know, a modded GS4 is hard to drive it easy
Originally Posted by PHML
I just got those same issue...CEL, VSC, VSC OFF....what to do?
Pete
Pete
Master Thread Closer!!
Originally Posted by DASHOCKER
You too Pete The Y2k bug must be lingering 6 years later. Ok get the car diagnosed at Auto Zone (free of charge) to see what codes pop up on the obd2 scantool, then we can work from there. It could be a number of things that can trigger those lights to pop up.
Pete
OK guys.....I fixed mines today by disconnecting battery, cleaning SRT intake, cleaning MAF sensor, cleaning throttlebody...all had gunk....after I started up the car and no CEL, VSC, and VSC OFF....I then went ahead and cleaned the engine bay with Simple Green and water hose (while engine is running).
Pete
Pete
I would still check for trouble codes at AutoZone. When I had my problem, I reset the ECU and the dash lights disappeared. It is normal for the dash lights to go out after disconnecting the battery terminal, or plucking the ecu fuse. That just clears the dash lights, but does not rectify the problem. I checked for trouble codes after I did the ecu reset, and the scanner detected the same trouble codes even though the lights are no longer lit on the dash. After the repair, I went back to AutoZone to have it scanned, and no codes. Good luck Pete.
OK...thanks....hmmmm....no Autozone here in Hawaii....gotta find somewhere else.
Pete
Me too...just happened this morning. Wasn't driving hard at all...heavy morning traffic. I hoped it was a glitch and would reset after I stopped for some java...returned to car, started her up and still had check engine, VSC, VSC OFF lights. Damn...this is a first for my car. Well, I plan on taking her in for an alignment check after I get new tires...might as well add this to the list.
In the mean time I'll pull the ECU fuse to reset and see if the error codes come back and they should if it's a true problem...if not..I think it's a glitch.
