aftermarket lsd's???
I am looking around for an supra lsd and came across this.lsd
Now , this will work for our cars being its for the automatic supra, right?Plus its $880 brand new. |
actually looking for a 3.76 compared to the 3.26 if I am correct.Also theP.I. t/c will help out.
That diff you linked to does not change the gearing. You will still be using the stock ring and pinion gears and just changing the carrier to clutch type LSD.
If you want the 3.76 gears, get the TT Supra/Torsen LSD. New about 1,400 or so. They can be found used, be careful to get the right one (many were NOT LSDs). And yes, the PI torque converter will definitely "help" :D |
Originally posted by FutureGS400 That diff you linked to does not change the gearing. You will still be using the stock ring and pinion gears and just changing the carrier to clutch type LSD. If you want the 3.76 gears, get the TT Supra/Torsen LSD. New about 1,400 or so. They can be found used, be careful to get the right one (many were NOT LSDs). And yes, the PI torque converter will definitely "help" :D |
if you want a used one of 96TT let me know
great price shipped ...chesper than that $880 |
does lsd cause vsc light to come on. how is lsd in winter slippery condition. does it help or confusethe traction control
Originally posted by HKS_GS430 does lsd cause vsc light to come on. how is lsd in winter slippery condition. does it help or confusethe traction control |
| All times are GMT -7. The time now is 01:33 PM. |
