stock gs300 quarter mile time
Originally posted by TRULUX
nobody
nobody
- 3.0-liter, twin-cam, 24-valve in-line 6 engine. Certified Low-Emission Vehicle (LEV)
- 220 hp @ 5,800, 220 lb-ft @ 3,800 torque
- Continuously Variable Valve Timing with intelligence (VVT-i)
- 0 to 60 in 7.8 seconds [1]
- Top track speed: 144 mph [1]
- Aerodynamic drag coefficient: 0.29
- Five-speed automatic Electronically Controlled Transmission with intelligence (ECT-i)
- Rear-wheel drive with Vehicle Stability Control (VSC) [2] integrating ABS and TRAC systems
- Estimated fuel consumption: 18/25 mpg city/highway [3]
- Vehicle-speed-sensing, progressive power-assisted rack-and-pinion steering
- Front suspension: Independent, double-wishbone with high-mount upper arm, coil springs, gas-pressurized shock absorbers with internal rebound springs, stabilizer bar
- Rear suspension: Independent, double-wishbone with aluminum upper arm and toe-control arm, coil springs, gas-pressurized shock absorbers, stabilizer bar
- 16 x 7.5-in alloy wheels with 225/55VR16 tires
Those numbers are a little higher than you will see in real world track times, considering that the GS400 numbers are over 1 sec better in magazines than the GS 300s, but people who track their stock GS400s usually end up getting closer to the magazines GS300 times.
arizonags300
GS - 1st Gen (1993-1997)
Oct 4, 2002 12:57 AM
