track times !!!!!!!!!
went to the track last weekend. but I was a little disappointed in my results. The best time I could manage was 14.7 in the 1/4 mile and from what other members say and do. Make better time. The track here is near the ocean so it is a little slippery. And on take off I did get wheel spin. I also know that gas here really suck.. It is dirty and low on octain, even though I did used aditives ( turbueno). do you guys think that this, with the track condition hurt my times that much.. I going to go again in a coulple of weeks , but this time with racing fuel and work on my take offs.. do any of you guys have wheel spin at the track and make better time. could my lack of exhaust be hurting my srt ecu set up?
any thought ?
Chu...
Hey,
any thought ?
yes I'm using the brake torque and all que goods you mention. that's where I get my wheel spin. I guess I'm just lanching to hard for the track condition... I'll work at it and see what happens
thanks again
Are you running on stock tires? Sounds like more traction would definitely help-but at least you do have the LSD to help you.
Try different launching techniques too-maybe w/o torque braking to reduce wheel spin?
I would think you should be in the very low 14s near 100 mph especially at a sea level track with cool, dense air. You might try re-setting your ECU again with some good gas and see if that helps. Let us know how you do...
What was your 60ft time?
MPH at the end?
Post all of the data you can as well as temperature, humidity and barometric pressure.
In proper conditions your car should go 13s easy.
I'll get them next time I go to the track.. they are just getting organized down here so they did not give out the time slips unless you asked for them... ..... I'm planning to go on saturday again, I'll let you know how I do
thanks
