Cel
Old May 19, 2004 | 03:51 AM
ballin's Avatar
ballin
Default Cel
I replace my factory spark plugs with a set of Torque Master plug from Carson Toyota last week. I noticed I had Check Engine Light came on. I disconnected the battery and left it for over an hour, and I reconnected the terminals. The start up after reconnecting the batteries left the car idling roughly up an down between 500 to 1000rpm. The CEL came off. I let the GS run like that for about 20 min, and proceeded to drive to feel the difference in the tune up. As soon as I step on the gas it would bogg out for a few second, and start picking up engine speed. The CEL came on again, and still is on till today.
Is this normal with changing spark plugs? Does anyone know what I did wrong, because I check all the wirings, and bolts.
Old May 19, 2004 | 03:59 AM
DaveGS4's Avatar
DaveGS4
Administrator Emeritus
Definitely not normal. Not sure what the problem could be though.
Make sure you got the right plugs?
Old May 19, 2004 | 07:40 AM
rominl's Avatar
rominl
exclusive matchup
not normal at all, a bad thing i would say...
are you sure you put all the ignition wire back in the right order?
KTGS300
Jan 7, 2018 02:08 PM
hcole05
RX - 1st Gen (1999-2003)
May 31, 2016 01:01 PM
Masters101
Sep 13, 2014 07:27 PM
ColeTrickl
Apr 28, 2010 09:38 PM
MidTownMan
Apr 3, 2010 11:10 PM
