Rumble when ac or heat is turned on
Old Nov 1, 2023 | 01:01 PM
Chrisv413's Avatar
Chrisv413
3rd Gear
Default Rumble when ac or heat is turned on
Hi, I’ve had my car since April of this year. At first the ac didn’t rumble when I used it or heat but after like 2 months it started. It usually doesn’t start immediately until recently which I think was due to cold weather. Any idea what it could be?
Update: I haven’t fully figured it out yet. It fully works heat and cold so I’m gonna check blower if anything. Honestly forgot about the post but haven’t had the money until recently. So I’ll update once I go deeper into it
Old Nov 30, 2023 | 02:29 PM
Shoopaluke's Avatar
Shoopaluke
8th Gear
bump cause ima new owner and trying to educate myself
Old Nov 30, 2023 | 06:00 PM
MikeFig82's Avatar
MikeFig82
In what location of the car is the rumble present? Under the hood, dash board........?
Old Dec 4, 2023 | 12:26 AM
Yodog's Avatar
Yodog
I have a rumble but it’s due to the rpm’s at idle bouncing because (i think) the electrical load from the ac compressor being in use stresses the whole system out. I’m thinking of doing the “big 3” electrical power/ground wiring upgrade, and hoping it will eliminate or mitigate this annoying issue.
but if your rumble is from something else, maybe you have a small leak in the exhaust system somewhere? Just a random guess but please do update us if you ever identify and fix your issue.
Old Feb 5, 2024 | 11:37 AM
Dawid's Avatar
Dawid
3rd Gear
it could be your ac blower, I just replaced min this week and its fairly inexpensive ill drop a few links but hopefully you've already resolved this issue
https://www.rockauto.com/en/catalog/...wer+motor,6916
Old Mar 16, 2024 | 07:12 AM
Yodog's Avatar
Yodog
Could be your condenser fan assembly, since you say it only rumbles when the ac is on. I assume it’s fine with the fan running but the ac button is off?
MiIdlyToxi
Dec 6, 2022 01:51 PM
DAVEB1980
Jul 28, 2022 04:40 AM
Lickskille
Jul 11, 2019 03:37 PM
herbSC3RSB
Feb 17, 2012 05:47 AM
booja
Jul 2, 2006 09:01 PM
