Getting ready to pull my old motor and switch my oil pan to my new motor. I see I can order a gasket for the lower pan but cant seem to find one for the upper pan. Is there a gasket or is it sealed using a gasket maker?
I believe it's only a Toyota gasket maker. You can also use the "Right Stuff" oil safe sealant and that typically works wonders when you go to re-install.
