Fuel tank gaskets?? What are they called?
Hey so I had one fuel tank changed out to another tank. And they foun these leaking and pulled them and need new ones. I believe they are fuel return line gaskets/seals/gromets. There are 3.
Please help me identify these. And or where I could get them. Thank you.
The first image is the diagram the dealer uses and wants me to tell them what part it is. The second is a better diagram. And I believe those lower 'gaskets are what I need...
you need 77171-30030 for just the gasket. if you have a few extra bucks and are going to be using the stock pieces, two of the lines have a rubber hose built into it on the fitting that you might want to consider changing. Part numbers 77256C and 77260 are the bulkheads plus the gasket if you feel so inclined. You'll need two of the 77256C if you are running the factory feed, return and vent lines.
Got em ya. They come in a 2 pack. They were that first exact part #. The part with the hose is like 60$ gonna skip it for now. Wait for my gte car for that..
