Waterpump leaking, Not from the gasket. Need Help 1UZFE
So my poor baby decided to overheat and go into limp mode a month ago (1 week after I changed my radiator due to cracking) But I took it as a blessing to do some work on her.
Problem: Ive replaced my waterpump gasket with high temp goo, and its still leaking but not from around the pump its coming from in the cap(in the picture) How can I fix this, and can I do it without taking the pump off this is the 4th time ive had to take everything apart because the first time I used a gasket to later find the older models used RTV
https://imgur.com/zuPsj2N
Water pump buddy....my dad's 1UZ just had this exact problem. It's quite the job to get to the leak as is, why wouldn't you replace the $150 water pump? The time and effort to reach it and re-caulk alone should justify the water pump replacement.
