1UZ VVTi Strange Idle
Old 03-13-18, 09:06 AM
supra9398
supra9398's Avatar
Default 1UZ VVTi Strange Idle
I have a 2000 SC 400 with a rather odd set of symptoms; a search here and elsewhere has not yielded anything quite the same. Here it goes:
With the transmission in "park," the engine idles normally. With the transmission in "neutral," the engine idles normally. With the transmission in "drive," however, the idle drops to about 300rpm, accompanied by quite a bit of shaking and a check engine light. Once I rev it, the check engine light disappears and it runs smoothly. I have no idea why this occurs only with the transmission in "drive."
Old 03-13-18, 09:23 AM
BiGEZ
BiGEZ's Avatar
Once the CEL comes on pull the codes to see what the issue is. Might have a bad coil, plug or something along that line. Pulling the code will point you in the right direction.
Old 03-13-18, 10:41 AM
DrAtomica
DrAtomica's Avatar
I almost have the same issue, except it doesn't go down to 300RPM and I don't get a CEL.
I've checked for leaks and also tried cleaning the throttle body. Usually I'd either shift to neutral in traffic or turn the AC on and the RPMs will go up.
Old 03-13-18, 12:25 PM
Zerodrag
Zerodrag's Avatar
Could it be an alternator charging issue? Could explain why the CEL comes on at low RPM and disappears when engine RPM increases?
Old 03-13-18, 01:27 PM
DrAtomica
DrAtomica's Avatar
Usually if the alternator has a charging issue the battery light will then come on.
Old 03-13-18, 02:33 PM
BiGEZ
BiGEZ's Avatar
No sure but I too noticed my 99 SC400 idles at 300 rpms sometimes at 250 rpms when at a stop and in D. foot on the brakes. However it is smooth as silk and never miss a beat. I did a full tune up, brand new everything including all vac lines. Still idles low when at a stop but always silky smooth. No CEL or anything, so I don't worry about anymore.
Old 03-13-18, 02:51 PM
DrAtomica
DrAtomica's Avatar
Maybe 1UZ VVT-i cars idle low? I don't know, I checked the shop manual it set it should be 650rpm +/-50RPM
No issues with my 98 400 either
Old 03-14-18, 03:24 PM
LEXXIUM
LEXXIUM's Avatar
What octain gas did you put in it last time filled up?
and have you done anything under the hood lately?
Old 03-15-18, 11:38 AM
supra9398
supra9398's Avatar
Hey, sorry for my slow reply. Thanks for the comments, everyone. I bought a code reader and plugged it in; it says "misfire detected" for cylinders 1, 2, 5, 7 and 8. What could cause that? The most I've done under the hood is rebuild the starter motor 11 months ago, and the car has been in storage since then (had a lot of personal crap going on). 91 octane gas, always.
Old 03-16-18, 08:33 AM
supra9398
supra9398's Avatar
Something major (fuel system, ECU, etc.) would likely affect all eight cylinders, yet something minor (coil, spark plug) would only affect one. I have misfires in five cylinders, for which I am at a loss for an explanation. Perhaps fresher gasoline could solve the issue, or is that overly optimistic? I am hesitant to try anything, as I do not want to damage it.
Old 03-16-18, 09:44 AM
GS34B
GS34B's Avatar
Did you add some fuel stabilizer to the tank before you parked it for that time?
Old 03-16-18, 07:48 PM
BiGEZ
BiGEZ's Avatar
Dump a bottle of lucus or similar fuel injector cleaner and fill her up with good quality gas.
Old 03-16-18, 08:12 PM
supra9398
supra9398's Avatar
No, I did not add any fuel stabilizer; I always doubted the effectiveness of such things. I will try BiGEZ's suggestion and see how that goes. I will update tomorrow.
Old 03-17-18, 10:51 AM
supra9398
supra9398's Avatar
I have put fresh gas in it, and while the check engine light no longer illuminates and the code reader no longer detects a misfire, it still idles just above 0 and feels quite rough.
Zodiac
09-28-19 02:03 PM
Jewcano
06-19-14 05:50 PM
sc300lexii
06-06-13 07:29 AM
xmssc300
12-13-12 09:57 AM
reloj
06-22-08 07:21 PM
Quick Reply: 1UZ VVTi Strange Idle
