Toyota engine names (codes) deciphered
What Do Toyota Engine Codes Mean?
Since it began around the turn of the century, Toyota has produced many engines. Modern Toyota engines, such as those we will be focusing on here (1988 to present) are designated by a coded naming system. Toyota uses this system to denote what technologies are on the engine and to differentiate between the same engine, with slight modifications, being used in different markets.
The coding system works simply: the first numeric character(s) represent the engine block's generation, the next one or two letters are the engine family, and the suffix, separated by a dash, lists the engine's features. For example, a 2GR-FE engine (used in the Avalon, RX 350 and Highlander) is a second-generation (2) engine in the GR-series featuring an economy narrow-angle valve direct overhead cam (F) with electronic fuel injection (E).
The suffixes for Toyota engine naming are as follows:
- A - Valvematic variable lift intake head
- B - Twin SU-style side-draft carburetors (1900s)
- B - Flexfuel (E85) compatible (motors built after 2000)
- C - Carburated / California Emissions Controlled
- D - Twin Downdraft carburetors
- E - Electronic Fuel injection
- F - Narrow-angle valve DOHC
- G - Wide-angle valve DOHC
- H - High compression, High pressure charged
- I - Single-point fuel injection
- J - Autochoke in early models, unknown pollution control later
- K - On-demand Atkinson cycle - non-hybrid engine
- L - Transverse
- M - Philippines' market
- N - CNG fuel
- P - LPG fuel
- R - Low Compression (uses 87 and below octane fuel)
- S - Swirl intake
- SE - D-4 Gasoline Direct Injection
- T - Turbocharged
- U - Japan-spec emissions w/ catalytic converter
- V - Common Rail Diesel Injection (D-4D)
- X - Atkinson cycle - hybrid engines
- Z - Supercharged
- L - Transverse
- N - CNG fuel
- P - LPG fuel
- S - Swirl intake
- T - Turbocharged
- Z - Supercharged
I have two engines one labels 3UZ-Z88 and the other labels 3ZU-Z20. Do you think I can interchange them for sc430? What is the meaning of the suffix?
thank 4
If you have a SC430 you need a 3UZ-FE, but you will need one from the same year as your car. I don't know the differences betwwen a 3UZ-FE found in a GS430 vs the SC430, so I couldn't tell you if an engine from that car would be a direct fit in a SC430
W/r/t "G - Wide-angle valve DOHC": curiously enough the valve angle is frequently 45° from the bore axis and 90° from the opposite valves... exactly like race and performance engines built since WW1 (Jaguar, Harley-Davidson, Chrysler hemis).
Where port flow is less important, the head casting is narrower and lighter with the shallower valve angle.
