A650E slow change up to top gear when cold
Hi
My A650E box in my IS300 is working very well (120K's) however on cold mornings the last shift up to top gear does not occur for about one kilometre. Once it has changed up box operates normally for rest of day.
This is not a summer problem only when mornings get colder. Is this a common problem. As I said the box is silky smooth once warm.
Cheers
Ric
Cheers
Ric
Interesting that you mention that. This is the same case with me, the gearbox won't shift to second until the RPM reaches 3000. This is only in cold temperatures. Transmission works fine for the rest of the day. Could be something the transmission electronically does because of the temperature or just the fact the fluid hasn't reached optimal temperature to give enough pressure (maybe).
rickyp39
11-05-10 12:18 PM
dcl8254
RX - 1st Gen (1999-2003)
01-04-09 07:56 PM
