Car won't start unless I pull EFI relay...and reinsert?
Hello, I recently sold my SC400 to one of my friends, it has been giving him problems for some time. I came to you guys because I could definitely use some advice.
Long story short, the car will not start unless he turns the ignition to the off position, pulls the efi relay out. Then he must turn the ignition to the on position, reinsert the efi relay, then the car will start. What could possibly be causing such a thing? I don't even know where to start? Could this be ECU related? Any step in the right direction on behalf of my friend would be infinitely appreciated. -Thank you in advance, -Ian |
Quote:
did you, or anyone, find the answer to this problem? Bad ecu? My 93 sc400 is now doing the same thing. |
I spent a lot of time troubleshooting a similar issue. Once I replaced the ECU, the car started immediately. My suggestion would be to start with the ECU. They can be found pretty cheaply on eBay.
Quote:
After some further digging into the problem, I don't even have to pull and replace the efi relay for the cel to come on. All I have to do is tap on it and it triggers the cel and starts right up. I swapped the dimmer relay to the efi spot and it does the same thing. Any thoughts? I'm thinking it's wiring related now, and hopefully not the ecu.
My problem was very similar in that my car would only start if I removed the relay and jumped two of the pins. Otherwise it would not start. New ECU and it fired up immediately.
My my suggestion would be to find an ECU on ebay from a seller that accepts returns. Pop it in and if the car still doesn't fire up, then return it. |
Ebay is an option, but so are Tanin if you want a guaranteed rebuild done right.
http://www.taninautoelectronix.com/1...ecu_repair.htm Hope this helps. |
coupla q's
where is the EFI relay what's a cel? |
Quote:
check this thread out https://www.clublexus.com/forums/per...n-t-start.html CEL = Check Engine Light |
| All times are GMT -7. The time now is 08:12 PM. |
