1jzgte vvti (JZS171) ECU PINOUT
Hello mates, have you still got the pinouts for the jzs171? I´m getting crazy with the wiring to my 1jz S14a.
To wich pins I need to get power and grounds? for what i read until this moment, i know the wires need to get power, BATT, +b, +b1, MREL, IGSW (this one it is when the ignition its in the position to crank right?), +BM (for the ETCS-I?), and EC (for ground right?)
So much aprecciated and thankful all the help.
Cheers
Cheers
hey, is this pinout still available? i also have a JZS171 Crown motorset that am trying to get running in a 67 mustang. i could use the pinout. could someone just post it here?
thanks so much for the email @hititup. trying to figure out the wiring now. which pins exactly need to be grounded, and which ones need to be fed with switched +12v and constant +12v battery power to run? ive been looking at some jzx100 wiring but i there are some inconsistencies that i'm unsure of.
This site should be your best friend if ur doing a swap. http://wilbo666.pbworks.com/w/search?q=jzs171
its a jzs171 harness and computer. im aware that they're different pinouts, but looking at the diagrams for the jzx100 and jzs171 i figured i could still find wires like MREL, BATT, IGSW and B+, etc. im assuming i can follow some of the wiring guides to get the engine to simply fire up eg; even if they're not for a jzs171 specifically, won't the wires that need to be grounded and fed +12 be the same, just in different locations in the pinout?
this is the writeup i was referring to.
http://www.supraforums.com/forum/sho...arness-diagram
heres a video of the guy walking through how to fire the engine out of the car, its a jzx100
http://s981.photobucket.com/user/lad...G0037.mp4.html
have u found a solution?
