cig lighter still not working
I am having zero luck with this cig lighter i have ran a seperate power line from the kick panel fuse box straight to the cig lighter and the ground is still good and i have no power at all the fuses are good even the one under the cig lighter i dont know what else to do
is there a penny in the cig lighter? probably not in this case but I would start with verifying that the wire you ran and the ground you have are good with a multi-meter or tester or even a 12V bulb. if you are getting 12v across them it should work unless the base socket part is broken or out of shape etc. etc.
epikeddie
Mar 10, 2012 07:16 PM
