Ac issues sc400 just serviced today
Old Aug 5, 2013 | 11:49 PM
Mandana76's Avatar
Mandana76
Exclamation Ac issues sc400 just serviced today
Today I had ac serviced on lexus sc400 1993.
Engine was swapped month ago from a lexus 95 . I knew car had leak before on ac 2 yrs ago but never fixed it.
There was no low pressure service valve anywhere after engine swap. I knew car had leak before on ac 2 yrs ago but never fixed it. I know low pressure valve must be on car to locate leaks and to fill freon.
Ac mechanic did leak test and decided to changed o rings on compressor, he rebuilt low pressure hose on compressor so it has a low pressure valve built on it and new hose , vacuumed ac refilled with r134 freon . Blowing cold air that was around 4 pm .....few hrs later ....
car will only blow cold air on MAx cold ....
If I adjust the temp to 65 or higher or reduce from max it will become hot air only!!!!
Any ideas....
Old Aug 6, 2013 | 12:58 AM
93Gotjuice's Avatar
93Gotjuice
I would take it back and have them check. You might still have a leak
potatomon
Jun 7, 2019 03:33 PM
rcargile
May 27, 2017 03:33 PM
lbq
Jul 19, 2008 02:09 PM
Mark Manzo
Jun 16, 2006 06:39 PM
jacques
Maintenance
Jun 28, 2005 08:49 PM
