97 SC300 Gated Shifter Wiring
Old 03-23-13, 06:23 PM
1WILLY1
1WILLY1's Avatar
Originally Posted by gunyvw
you seemed to be leaning that way in your previous posts. i almost sold mine after having it nearly 2 years and i literally just installed it in the past weeks.
it took all of an hour maybe 2 with b.s. ing around. the shifter linkage was more pain because i welded it wrong and had to snap it and redo the weld make sure that the finished rod is contoured EXACTLY like the one you take off if you decide to cut it as mine bumped into the tranny at one bend point and wouldn't allow the shifter to move.
yes^^^ if im not mistaken the linkage need sto be shortened by about 1 inch or so , I have a book that i write these things down in ,,with the proper links and threads and useful info etc...
If I find a shifter with a d4 ill jump on it ,,if not ill just keep waiting
Old 03-24-13, 02:16 AM
gunyvw
gunyvw's Avatar
i know right with the demand for the shifter going up somebody needs to marry something like this
from an audi TT automatic...
https://www.clublexus.com/forums/att...1&d=1364116213
to one of these shifter bezels from luxury mods...
https://www.clublexus.com/forums/att...1&d=1364116407
and stick the overdrive button on the left floor...lol
Attached Thumbnails 97 SC300 Gated Shifter Wiring-kgrhqr-rifd0wrcf-pbq98fb4ssg-60_57.jpg   97 SC300 Gated Shifter Wiring-heated_shift.jpg
Old 03-24-13, 05:35 PM
SSmith
SSmith's Avatar
Wiring all updated on page one. Everything works like it should.
Shane
Old 03-24-13, 07:45 PM
SSmith
SSmith's Avatar
Guess the thread got moved. Here are finished pics of the harness. I had an extra cig plug which fits the 97 connector going to TRAC switch. Now everything is plug and play.
Shane
Attached Thumbnails 97 SC300 Gated Shifter Wiring-harness2.jpg   97 SC300 Gated Shifter Wiring-harness1.jpg
Old 02-14-15, 11:10 AM
SoCalAV
SoCalAV's Avatar
Default TRACY switch location
For SCs factory equipped with bezels that do not have space for the TRAC switch the alternate location for the switch is a covered cutout located to the immediate right of the fuel tank and trunk release lever assembly under the left dash. The switch is a different form factor, but it's the intended spot. The correct switch can be ordered from Lexus parts suppliers or found in salvage yards. Extending wires may be required.
SSmith
SC- 1st Gen (1992-2000)
13
10-11-12 09:16 PM
TroySC300
18
12-09-10 10:45 PM
prjctSC300
SC400 / 300 Classifieds
10-12-04 09:21 PM
Din
14
04-30-04 02:51 AM
Quick Reply: 97 SC300 Gated Shifter Wiring
