Gas smell on start up and bad gas mileage
Old 01-07-13, 02:54 PM
SpadedOne
SpadedOne's Avatar
Default Gas smell on start up and bad gas mileage
Resently my car started having a really strong gas smell out the exhaust when I first start the car up. Usually goes away in a few minutes. I've noticed I'm getting horrible gas mileage now to, like maybe 10 miles a gallon. No check engine lights and no codes. Where should I start to try and solve this? TPS? Plugs?
Plugs and timing belt where done with 172,000 miles in 2007, and now has 191,500. It runs really good and smooth. Slight hesitation occasionally, but that seems pretty common.
Old 01-07-13, 03:05 PM
Ali SC3
Ali SC3's Avatar
Check/replace your oxygen sensors if you have never done it, they are recommended every 60k, and after 150+ they are definitely dead and probably not even registering anything.
If it is your o2 sensors and you fix it that slight hesitation should also go away, an SC4 runs a little rich most of the time anyways, but when your o2's are dead and you are running really rich as in no trims at all, it will loose performance, loose power, and loose MPG.
If you hadn't said it ran really smooth, I would also say check over the ignition stuff alot of times one of the 2 coils will go out, it will run on just 4 instead of 8 suck down gas and have general bad performance. problem is these motors run so smooth alot of people cant tell if its on 4 or 8 so they check everything else.
Old 01-07-13, 07:50 PM
snakehead
snakehead's Avatar
Check for leaky injector , bad o ring ...
Old 01-08-13, 07:14 AM
SC400slide
In Recovery Mode
SC400slide's Avatar
O2 sensors would do this. I suggest you replace the front ones.
budmantom
12-22-14 07:42 AM
guku0701
SC- 1st Gen (1992-2000)
30
04-24-12 09:13 AM
swiftscsi
ES - 5th Gen (2007-2012)
13
08-27-10 05:55 PM
breakb
03-22-08 01:51 PM
1sxyrxy
25
02-26-07 06:16 AM
Quick Reply: Gas smell on start up and bad gas mileage
