trac light problem
Old 12-14-12, 12:56 PM
Markysc4
Markysc4's Avatar
Default trac light problem
Whats up my fellow sc owners I just ran into a little problem ...I started to drive my sc which is a 400 and my trac light came on I pulled over shut her off and started back up trac light went off haven't came back on yet but can someone please tell me what is the problem...thank you
Old 12-14-12, 12:57 PM
SC400slide
In Recovery Mode
SC400slide's Avatar
You hit a pothole.
Old 12-14-12, 01:03 PM
Markysc4
Markysc4's Avatar
Lol really ? Usually it'd start blinking not stay on
Old 12-14-12, 01:34 PM
SC400slide
In Recovery Mode
SC400slide's Avatar
I was sorta being sarcastic, Lexus CEL go on if you drop a tennis ball too close to it. I wouldn't worry about it if the light didn't stay illuminated.
Old 12-14-12, 02:01 PM
Kalogerus
Kalogerus's Avatar
There is an accumulator next to the master cylinder on the driver side under the hood, get a plastic line and attach it to the nipple and the other end into a bucket and loosen the nipple to remove any air from there. Also attached to that accumulator is a high pressure line, check if it is cracked/hard/bulged/damaged.
I have been trying to locate this hose by itself but it comes with the accumulator as a set. Got a used one for 50 shipped off of ebay.
PS. If you're going to replace, before you take anything else apart, save yourself a lot of hassle and see if you have the tools to remove the hose first. The transmission dipstick wont allow anything over an inch in width in between and u need a lot of torque to loosen that sucker.
CheVelleSS
12-14-13 03:30 PM
simrx3
11-12-13 06:01 PM
johnnybmw1
SC- 1st Gen (1992-2000)
06-11-09 11:40 PM
mac187
GS - 1st Gen (1993-1997)
09-09-08 04:26 AM
mjr24
21
11-24-02 06:12 AM
Quick Reply: trac light problem
