Free Toyota Pre-OBD Datalogger Found!!
It came with a male, a female and a strip of 9 pins to solder your own configuration.
I used the pins on the DLC2 Side, as they fit into the spade receiver really well, they're just really fragile, so you can't move them around too much.
The other (Smart) option is to build the cable, and use a "Snap-on Diagnostic end". They sell them for the obd-1 plug like we find in the SC's.
http://www.obd2-diagnostic.com/for-t...-adapter-cable
im going to get it and cut off the 16 pin connector, build a new cable, and see how it turns out.
Dunno if this one works, but it was cheap and i figured it was worth 8 bucks
But i think i got some wrong settings, because i checked the cable and it was okay but the programm didn´t log.
At first: When i´m clicking on "MORE" --> "CHECK THE CABLE ON THE INVERSION"
The number jumps from 1 to 0 all the time... 1,0,1,0,1,0,1,0,1,0,1,0,1,0 etc....
And i got a screenshot from the options here:
Can someone please tell me/ us what setting we need for a 1JZ/ 2JZ engine please?
And what value do i need in "PERFORNAMCE OF INJECTORS" ?
I´m running JDM 440cc injectors in my 1J.
Thanks for your help guys.
If you didn't get a 1, you would leave it un-checked.
Since you have a 1jz, check "1jz"!
You have a MAP-Turbo KPA.
GR/ sec is also "CC's / sec". So you would have 44 gr/ sec for 440cc injectors.
With the car running, you should get logging with these parameters.
Just wondering if this would work on my 2000 GS300 as I have a Toyota diagnostic port in my engine bay also.
And is there a straight connection from the Toyota diagnostic plug (pin VF1) to the OBD2 plug somewhere? As I want to build this cable and use it on my OBD2 plug instead of the Toyota diagnostic plug.
