1JZ (or 2JZGTE) basic wiring question (searched)
I know from talking to a few people that you only need maybe 7-8 wires total to have your swapped 1JZ/2JZ engine harness, spliced into the project car's chassis/dash/starting harness and have the car idling and running. Does anyone know what are the minimum mandatory pin outs that need to be connected from the engine harness? I can clean up the harness and get all the gauges and what nots wired in once the car is running and able to move on its own.
There were a few on the main ECU harness, then there were a few on the Kick panel interface harness.
I know you need Power and ground to the Stock ECU.
I know you also need to connect the thick Black/orange power wires... ( cant remember which pinout, etc.)
I know you need to trigger your fuel pump, and igniter (cant remember which pinout)
Any links or feedback you can provide would be greatly appreciated.
Thanks,
Rich
Understood.... I'm thinking about building a time attack car with a 1JZ/W58 or 1JZ/R154 so the dash, HVAC, power windows and all the bells and whistles will be somewhat irrelevant. Since I plan on running 15psi or so... I don't think a standalone is cost effective, where a stock ECU can easily do an adequate job.
Once the car is driving, I can focus on gauges or simply buy all new more accurate gauges and mount them into an aluminum dash panel or something. (will cross that bridge when I get to it)
are those 7-11 wires proprietary information or are you willing to share? I'm thinking about an non VVTi 1JZGTE/5spd swap. i assume once the factory ECU is plugged in those 7-11 wires are similar in all the Toyota swaps.
EB2 connector is a 3 pin connector and is near the igniter
EB1 connector is a 6 pin connector and is near the igniter
IJ2 connector is 17 pin connector near the ECU is dark gray, has 2 rows of pins.
You need switched power to EB2(2). This is a black and orange wire.
You need switched power to EB2(3). This is a black and red wire
You need switched power to IJ2(11). This is a black and orange wire.
You need constant power to EB1(4). This is a black and yellow wire
To start you need to supply "start" power to EB2(1) which is a black wire.
And of course you need to figure out what it takes to turn your fuel pump on. Different on every vehicle.
